Duplicate Filenames and Multiple Canon EOS Cameras
xplorer-3
Post by xplorer-3 »
Is there an easy way (program) to prevent duplicate file names when transferring pics via card readers from multiple Canon EOS devices which all have the same filename format "IMG-xxxx". Specifying downloads to a dated folder name exacerbates the problem when combining the pics into a common folder at a later time. We have been manually renaming but this is becoming burdensome. Was wondering if PSP X4 has a front end downloading program that could handle this. Thanks in advance for any suggestions. Mike
Re: Duplicate Filenames and Multiple Canon EOS Cameras
Post by Trevor Andrew »
I use the Canon Utility to transfer my images.
I viewed the Canon software and it allows you to choose a new file name rather than using the default camera name.
Windows Explorer can batch rename if that will help with the existing files.
Using Ctrl+A will select all, now right click the first and re-name, all files will be renamed plus a prefix number.
Batch rename software may help, one called Bulk-Rename was quite good and could rename to any format, a little difficult to use, but excellant results
Not sure about PSP?
Edited
Just tried PSP to import from camera, the program uses the cameras file names.
However there is a Re-Name option using PSP X4?
ronzie
motherboard: ASUS P4-800E Deluxe
processor: Intel P4 3.3 GHz
Video Card: PNY GT6800 AGPx8
sound_card: Hercules Digifire 7.1
Hard_Drive_Capacity: 360 GB
Monitor/Display Make & Model: NEC Multisync P221W with Spectraview Calibrator
Post by ronzie »
This $30 download utility allows camera metadata from the exif or dnc formats embedded in the image to be added to folder and image title. You set up a macro format for the folder and for the image which also has a macro field available that will prompt you for input. It can use your camera direct USB (Canon specific models) or card reader (most brands) and will via either provide thumbs so you can select from the card storage those you wish to download. For me this allows me to name folders by subject besides the actual shooting timestamp to the file/folder name. The there is a symbol for camera type as well.
http://www.breezesys.com/Downloader/features.htm
Here are just some of the symbols (tokens) than can be added to the folder and file names. Note camera model is one of them. In addition if the camera allows you to input an owner name into its storage fields that also might prove useful to you if your cameras are specifically assigned to certain staff.
