You can see that the cloning is blotchy and just isn't right....any help would be appreciated.
For me, the experience between Photoshop's clone tool and PSP's is nearly identical. Although, PSP is a bit faster just from different hotkeys (changing brush size and sample selection is much much faster in PSP). Some images (and portions of images) are harder to clone than others. If you are having a hard time doing what you want in PSP, open it up in Photoshop and see if you can do what you want with it. If you can't do it there, then perhaps the image is too much work to correct. I've rarely come across an image like this....it just depends on how much time and effort you want to put into it, and if the fix is worth it to you! In the end, they are just tools that are available for you to use. And it seems that no matter how long you've been into photo editing, and how much you know....there is always something more to learn (new tricks and techniques).arkitekt878 wrote:Surely sampling once is enough. As I move the clone tool across the line the sample point moves with it. So I would have thought that getting close to the line, taking a sample and then moving along should work. Or maybe I'm reading the situation totally wrong. However as you say practice makes perfect but I honestly have to say I never had this much trouble with, dare I say it, Photoshop.
Good job Ken!Ken Berry wrote:A pretty quick (and admittedly thus imperfect) application of some of the suggestions made by brucet:
