Making vector text "closed path"
Torrianthane
operating_system: Vista Ultimate
motherboard: Acer EM61SM-EM61PM
processor: AMD Athlon 64 X2 Dual Core 3800+ 2.00Ghz
Video Card: NVIDIA GeForce 6150SE nForce 430
sound_card: High Definition Audio Device
Hard_Drive_Capacity: 54.21 GB
Monitor/Display Make & Model: DELL 2208WFP 22.0"
Post by Torrianthane »
Is there any way to make vector text bear the characteristic of "closed path data"? Perhaps prior to, or after, applying the text in PSP? I am trying to import files from Corel PaintShop Photo Pro into MotionStudio 3D. I am able to bring in vector objects created, but is there a way to make it so that vector text works also, by making vector text "closed"?
Thanks!
df
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Re: Making vector text "closed path"
Post by df »
If you mean for the text to follow the path after it's been closed and continue from the end point to the beginning and keep following the path I don't think so. But I don't use vector paths very much at all.
Regards, Dan
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
I too am slightly confused by what you mean by "closed." A closed path is one that has one node that is both the start and end point with no gaps. So technically text is already closed.
However, text is not a path in the same sense as what motion 3D might consider a path. In order to make Text a path you must convert it to a path. You can either do this as one giant path or making each character its own vector path.
Go to the Objects menu and select the options for "Convert to Path." That will handle that.
Torrianthane
Thank-you, I will try that.
