Digital Noise Removal Problem?
WilsonC
Monitor/Display Make & Model: Samsung SA300
Post by WilsonC »
First, I know I've posted a lot about 'bugs' and problems I've encountered with the software. But, I actually do like using the software and I do like the updates and where it is heading. 8)
I ran into a small problem last night when using the Digital Noise Removal plugin. I was playing with settings and unlinked the Noise Correction sliders and moved them about. Then I tried linking them back and clicked on the Large slider to make further adjustments when a blank alert dialog popped up. I can click the blank button and it disappears and seems to continue work, although the settings barely move. Each time I adjust the Large slider after this I get the same dialog.
Once again, can anybody else duplicate this?
-Christopher
Joelle
ram: 16 GB RAM
Hard_Drive_Capacity: 1TB
Re: Digital Noise Removal Problem?
Post by Joelle »
I can't replicate this.
I un-linked the settings, entered your numbers, re-linked, Applied.
No problems.
Sorry Christopher, but it works as it should here.
Strange numbers though :-)
Joëlle
Joëlle
(PSPX9 )
WilsonC
Post by WilsonC »
Joelle wrote:I can't replicate this.
No problems.
Joëlle
Darn, another problem just for me! :shock: Yeah, the numbers were completely random just for the screenshot!
-Christopher
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Post by teknisyan »
It can be a problem with your workspace. Have you tried resetting the PSP X4 Workspace?
You can do that by pressing and holding down the SHIFT key then double-click on the PSP icon then when you received the message "DO YOU WAN TO RESTORE PAINTSHOP Pro TO ITS DEFAULT STATE?" just click OK.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
WilsonC
Post by WilsonC »
Abiel Corel NA wrote:It can be a problem with your workspace. Have you tried resetting the PSP X4 Workspace?
Haven't tried that yet, Abiel. Will that reset my preferences or customized hotkeys?
-Christopher
WilsonC
Post by WilsonC »
I just gave it a shot, but the empty dialog pops up still. Kinda strange. As long as I know it's there then I can work around it. I will have to check my other system and see if I can duplicate it there.
As a side note, it appears that customized hotkeys are stored with a workspace? (which is very, very nice)
-Christopher
WilsonC
Post by WilsonC »
Ok, did another quick test on my other system. This is on a laptop running Win7 64. I get the same dialog, but this time there is text!
-Christopher
flagpole
motherboard: Gigabyte B450 AORUS ELITE DDR4 USB 3.1 RGB
processor: Ryzen 2600
Video Card: RTX 2060
sound_card: on board
Hard_Drive_Capacity: 6.5TB
Monitor/Display Make & Model: Iiyama 27"
Post by flagpole »
there does seem to be something a bit strange. when i unlink them and link them again, and slide them about i get a bonging noise like i would expect to get as a pop up occurs but no pop up.
the logic seems a bit confused too. i don't know if it's by design or not but if you set them to different values and re link them they move together but at their respective levels until one of them can't move any more where it waits and they all go back to sync.
WilsonC
Post by WilsonC »
I just noticed that I only get the pop up when using the drop-arrow quick adjustment thingy to change the settings. When I use the up and down arrows then I don't get the pop up at all.
-Christopher
df
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Post by df »
Just a thought, what security software do you have? This may be something else taking focus in the OS, sometimes security software can do that.
Try this, open your task manager (Ctrl Shift Esc), click the performance tab, click Resource Monitor...
On the Resouce Monitor window click the CPU tab. Find your security software's process.
Now go back to PSP and recreate your error, imediately jump back to Resource Monitor. Did your CPU usage for that security process spike? If so, you may want to create an exception for PSP in your security software.
Regards, Dan
WilsonC
Post by WilsonC »
Thanks for the input! I'm running Norton on both systems. Looking at the performance before and immediately after the problem I cannot spot any difference in the statistics for that process. I also tried setting exceptions for PSP with Norton, and it did not seem to affect the pop up problem.
-Christopher
JStanley
Post by JStanley »
deleted
flagpole
Post by flagpole »
i'm pretty sure it is just a bug in the program surrounding how it handles the problem of when the parameters are set differently then linked and the adjustment of one causes clipping in another.
df
ram: 64gb
Post by df »
WilsonC wrote:Thanks for the input! I'm running Norton on both systems. Looking at the performance before and immediately after the problem I cannot spot any difference in the statistics for that process. I also tried setting exceptions for PSP with Norton, and it did not seem to affect the pop up problem.
If you sort by Average CPU usage is there any other process that's spiking when you do something in PSP?
Regards, Dan
WilsonC
Post by WilsonC »
The only other thing that pops up to the top of the CPU usage is the "audiodg" service. Which I assume has to do with the audio alert that I am getting from the pop-up (same as others have posted above). I appreciate all the input. It appears that I will have to avoid using the drop arrow slider input since the up and down arrows work without triggering the alert pop-up.
-Christopher
