The original clip is a NTCS HDMV file format (with the .m2ts extension), H.264 video 720p60 (16:9), digital Audio Dolby (AAC).
I'm able to do the first 2 steps without any problem. However, when I want to save the result in a file, I cannot find any way to indicate the software to save in the same format as the original clip. So I am looking for any way to save the video in a 720p60 (59.94 to be accurate) with the same video and audio codec that can be read by a PS3 console (H264, AAC) as a .m2ts file.
Is it possible to do this using VS Pro X4? Or do I need to use a non-trial version? Or do I need to use the Ultimate version? Or is it simply impossible to do this (yet)?
Things I tried:
- When I want to create a video file, and choose "as per project's parameters". But it appears they are set to NTSC SD for DVD-like output. If I go in the project's parameters menu, there is no way I can set the resolution to 720p60 HD.
- Among the AVCHD outputs in "Create a video file", I only find 1080i and 1080p resolutions. Same for Blu-Ray outputs. Why is there no 720p resolution in both outputs?
- In the "Customized" output, there is no way I can set the resolution to 720p60 HD. Is it normal?
