Comparing X3 and X4 ...
Is there no way to use the eraser (or delete selections) on adjustment layers? I do/did this routinely in X3. Please tell me I have missed some sort of configuration setting in X4!?
Thanks!
Kevin
X4: Can't use eraser on adjustment layers??
kchildress
- ram: 16 Gb
- Hard_Drive_Capacity: 2 Tb
WilsonC
- Monitor/Display Make & Model: Samsung SA300
Re: X4: Can't use eraser on adjustment layers??
You can paint with a black brush to remove the effect from certain areas.
-Christopher
kchildress
- ram: 16 Gb
Right. Of course you can ...WilsonC wrote:You can paint with a black brush to remove the effect from certain areas.
Thank you, WilsonC
