The dialog box for "Adjust/Highlight-midtone-shadow" has become "locked" at the very top-left corner of my monitor screen.
It's top "grab-bar" and "shadows-value-field" are outside the edges of my monitor.
I cannot "grab" it with my mouse cursor to relocate it. How can I move it into the visible area of my monitor?
PSPX3 Dialog Box is locked in top-left corner .. cannot move
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: PSPX3 Dialog Box is locked in top-left corner .. cannot
When the dialog box is visible hit the "Alt" key and then hit the "down-arrow" on your keyboard. This should open up the default window context menu. Select "Move" from the list. Now use the arrow keys to move it around.
This should allow you to drag the dialog fully onto the screen once more.
Sal
- motherboard: Belarc Advisor
- processor: Belarc Advisor
- ram: 4GB
- Video Card: Belarc Advisor
- sound_card: Belarc Advisor
- Hard_Drive_Capacity: Belarc Adv
I had something similar to this happen in PSPX2 with the Organizer on the bottom of my screen - when I "grabbed onto the resize area of the organizer and raised it up, it was "above" my Layers Palette and I couldn't see the Layers at all. Through some help in a forum, I finally figured out that going to "File, File Preferences, Reset Preferences (to factory default) was all I had to do to go back to the original settings. You have to reopen the Materials Palette, Layers Palette, and any favorites toolbars you normally like to have open but it got past the frustration. Hope this helps someone.
Moderator Note - Sal , please RUN the programme Belarc Advisor and fill in the details it provides in your profile
TwoRails
- motherboard: Asus P8P67
- processor: i7-2600
- Video Card: GeForce GTX 560 Ti
- sound_card: RealTek
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: View Sonic P220f
That worked for my stuck dialog box in X2... Thanks!LeviFiction wrote:When the dialog box is visible hit the "Alt" key and then hit the "down-arrow" on your keyboard. This should open up the default window context menu. Select "Move" from the list. Now use the arrow keys to move it around.
