I have just upgraded to PSPX4 from X2, but have been using PSP since it was a JASC product. So far I am not very impressed with the new version. My first stumbling block was when I couldn't increase the canvas size on a photo that I'm restoring (9120w x 13298h). A chat session with Corel identified the issue as being a 10000 pixel limitation now being imposed. Although I can work with images >10000, I can't increase any dimension past this figure. Who had that brainwave? I had to put my image into PSPX2, increase the canvase size and then load it back into PSPX4 to continue.
Now today, another issue pops up. I can't seem to find other hits on pasting selections within the forum though, so I am raising this.
I loaded two tif images into my Edit workspace. One image is fairly small and I copied this, switched to the larger image and tried a 'paste as new selection'. This worked OK. The I switched to a paintbrush and made a small change to the main image. I then tried pasting the copied image again with 'paste as new selection'. This time the program locked up with Windows trying to find a resolution. PSPX4 then crashed. I have tried various scenario's to narrow the cause down. So far it seems that I can paste a new selection as many times as I want, but as soon as I use a paintbrush to effect even a small change PSPX4 locks up. It either then crashes, as explained earlier, or I get the round no operation mouse cursor displayed. At this point the main control box buttons (close, minimize etc.) won't respond, neither can I switch to the Manage or Adjust areas. The menu trees respond, but selecting File/Exit doesn't work. I have to use Task Manager to close the program.
I had installed SP1, but trying to identify the cause of this issue I uninstalled X4 and reinstalled the base version from CD (332). All settings were left to default. This is how I am running now, so it looks as if SP1 makes no difference. I have also tried using jpg instead of tif, but this also makes no difference. At the moment I'm thinking of ditching X4 and going back to X2.
Has anyone else come across this issue?
I am running Windows 7 Ultimate 64 bit with 8Gb RAM.
PSPX4 paste selection issue
Jeepster56
- motherboard: Gigabyte GA-H67MA-D2H-B3
- processor: Intel Core i5 2500K
- ram: 8Gb
- Video Card: Not applicable
- sound_card: Onboard
- Hard_Drive_Capacity: 6Tb
- Monitor/Display Make & Model: Samsung SyncMaster 226cw
marty2010
- motherboard: Gigabyte Z68A-D3H-B3
- processor: Intel Core i7 2600k
- Video Card: NVIDIA GeForce GTX 550 Ti 1GB 8.17.12.8026
- sound_card: Realtek
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: Viewsonic , VX2250WM-LED, 2 each
Re: PSPX4 paste selection issue
I did a quick test X$-SP1 with two JPGs.
No problem.
Maybe I did not test exactly .. what you did.
No problem.
Best Regards,
Vaughan Martell
Vaughan Martell
