PSPx4 Bugs and fixes.
SJS
motherboard: Dell Inc 0KWVT8 A03
processor: 11th Gen Intel Core TM i7-11700
ram: 16 GB
Video Card: NVIDIA GeForce GTX 1660 Ti 6GB GDDR6
sound_card: Onboard Realtek Codec
Hard_Drive_Capacity: 4 TB
Monitor/Display Make & Model: DELL U2412M
Corel programs: PaintshopPro 2022 Ultimate
Re: PSPx4 Bugs and fixes.
Post by SJS »
Where should I look for reported bugs to avoid repeating known problems?
I did look around but did not find such a list of know problems ...
brucet
operating_system: Windows 8.1
Post by brucet »
The idea is to search through and discuss issues in other threads. Then if no solution is found this thread becomes the home of apparent bugs.
Regards
Robolovsky
motherboard: ASUSTeK Computer INC. P7P55 LX Rev X.0x
processor: 2.95 gigahertz Intel Core i7 870
Video Card: NVIDIA GeForce GTS 450
sound_card: VIA High Definition Audio
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Iiyama PL2410HD
Post by Robolovsky »
timmendorf wrote:If you have customized all your icons nicely in Edit mode, then go into Manage mode and there change from Preview to Thumbnail view, then go back to Edit mode, all your additional icons are gone.
Comment: Unbelievable bad programming.
Actually this happens even if you just flick back and forth between the Manage and Edit tabs. You don't have to switch to thumbnail mode. Awful!
Robolovsky
It is not possible to switch between Edit and Manage modes without closing any images you have open for editing. The general feeling seems to be that this is not a problem as the Organizer (File manager) is available in Edit mode anyway so there is no need to go to the Manage tab. However I would disagree with this as some of my folders contain large numbers of images and it is much easier to browse through them using Manager in thumbnail mode as you can see far more images at once than with the Organizer in Edit mode. Also I find that Organizer gets in the way in Edit mode and would much prefer to switch back and forth to the Manager as was possible in X3.
Even if this problem does not affect everyone it is still difficult to understand why Corel would insist that images in the Editor are closed before switching to Manage mode. I cannot personally think of one reason why this would be preferable.
DigitalDave
motherboard: Asus Rampage Extreme
processor: Q9650
ram: 4GB
Video Card: Radeon HD 4870
sound_card: SoundMax Pro
Hard_Drive_Capacity: 600GB
Monitor/Display Make & Model: Dual Dell 22" 1920x1080
Post by DigitalDave »
Simone Corel UK wrote:Opens always images with 72ppi.
PSPX4, 14.0.0.332
Image -> Resize:
  • 1. change to higher ppi
    2. File - Save: result fine and can be confirmed in other photo editing programs
    3. Re-open in PSPX4, it's again shown as 72ppi
PSPX4, 14.1.0.5, SP1:
Do 1. to 3. in PSPX4 SP 1 and save as JPG
Result: it works fine.
JPGs from cameras or photo editing programs like Photoshop are still opened with 72ppi.
Other formats like PNG and TIFF seem to be fine.
Already addressed to the DevTeam. No further bug report required.
Actually I've reported a bug with PNG file format 6 years in a row with nothing accomplished, and it's easily reproduceable:
1. Open any existing PNG file.
2. Resize it, changing ppcm to ppi. Leave it at 100% if you wish.
3. Save the file and close it.
4. Open the file. The dimensions are back to ppcm.
Default resolution in preferences is set to 192 ppi.
PNG file format is the only one that can't retain the ppi setting and I can't imagine this would be difficult to address.
I write software. If you let me have the section of the code that saves PNG files I can likely have the answer for you in a few minutes.
Regards.
JCA
processor: Intel Core i7 2630QM 20GHz
Video Card: GeForce GTX 560M 3GB
sound_card: Sound Blaster X-Fi HD
Hard_Drive_Capacity: +2TB
Post by JCA »
I've noticed these things:
1) Zooming doesn't work as expected. This includes both mousewheel zoom and the zoom tool.
2) All the adjustment layer dialogs appear to be cut off from the right side, though all the controls in them are still useable. Resizing the dialog has no effect. Easiest to notice with the Levels adjustment layer. The adjustments launched from the Adjust menu don't have this issue.
3) Adjustment layers do something even with all properties at 0. Example: Make an image with 128 128 128 color, then add a Brightness/Contrast adjustment layer.. and check the color of the image and you'll notice it's 127 127 127.
4) The number value in the Opacity slider in the layer panel goes partially outside of the slider area when the number value is below 80 (at that point it goes to the other side of the arrow/line thing).
5) There are some useless Undo/Redo actions appearing. Example: I have image with a dozen layers, I use blur on one layer, I select another layer and press repeat.. instead of repeating the blur on the layer, it repeats the layer selecting! Now why would I want to repeat that action?
6) Offset effect doesn't work properly with positive Horizontal offset and negative Vertical offset. Some pixels disappear and some are duplicated. Easy to notice by making a grid with equal sized squares and then offset it a few times with values that are the size of one square in the grid and Edge mode Wrap. Eventually you'll notice that the squares are no longer equal sized. Negative Horizontal offset and positive Vertical offset values work fine.
7) Sometimes when I've tried to save a file without the file type extension typed in the filename, it doesn't save the file, because it's not a valid file type extension.. but sometimes it does save it. I suspect it's got something to do with saving the file with one type, then saving it again with a different type and different name.
Some of these bugs have existed before X4. I think the bug number 6 has existed already in version 8. Bugs number 3 and 4 I noticed with X3. Bugs number 1, 2 and 4 may have something to do with having a 16:9 monitor, at least I didn't notice number 4 with my earlier 16:10 monitor.
ADonahoo
motherboard: Dell Inc. 0KWVT8 A03
processor: 3.60 gigahertz Intel Core i7-4790
ram: 24GB
Video Card: AMD Radeon R9 270
sound_card: Creative SB X-Fi Titanium
Hard_Drive_Capacity: 13256GB
Monitor/Display Make & Model: Dell SX2210 and Dell ST2210
Corel programs: PSP X7, X8, X9, 2018, 2019
Post by ADonahoo »
JCA wrote:I've noticed these things:
I put in a support ticket on this issue, and it was finally "sent to Resource and Development for further investigation" after a couple of weeks of back and forth with the tech telling me to reset my workspace and reinstall the program, and me telling him repeatedly to go look at older versions of PSP and see how this function is supposed to work.
B4b5
Post by B4b5 »
PSP w/Wacom tablet Fix.
For anyone trying to get PSP_X4 to recognize pressure sensitivity on your Wacom Graphire-4.
On my Win-7 (64bit) using PSPx4 with Wacom Graphire-4, It seems to work best with Driver 5.24-6 RC for Windows 7, Vista (32 and 64 bit) and XP.
Here is the Wacom download-> ftp://ftp.wacom-europe.com/pub/WINDOWS/ ... -6_int.exe
I find that the tools look best with File->Preferences->General Program Preferences->Display and Caching-> (deselect) Show brush outlines...
JCA
Post by JCA »
I have a small addition to the 4) The number value in the Opacity slider in the layer panel goes partially outside of the slider area when the number value is below 80 (at that point it goes to the other side of the arrow/line thing).
Windows 7 seems to default text, icon, etc sizes to 125%. When that setting is decreased to 100%, the number value is no longer outside the slider area. Though it still at the very edge of the slider area. Perhaps solution could be to make the slider area wider or move the number a bit to the left. Shouldn't the number 100 be centered instead of the number 1 in it start from the center?
Also I'm seeing a horizontal scroll bar at the bottom of the layer panel when there's nothing that would actually need scrolling. This happens if I have the right side of the layer panel fit to the elements it has. I have to make that part about 2 times wider than it needs to be to remove the scroll bar.
Simone Corel UK
Alludo
Post by Simone Corel UK »
@ JCA: This has been escalated a few months ago, shortly before SP 1 came out.
New issue logged as bug: Alpha channel gets corrupted when saving as TGA
zenxtang
processor: Intel Core 2 Quad
Post by zenxtang »
I didn't get a chance to read through the pages of post to see if this is a reported bug or not, so sorry if it is a repeat.
There is a bug in the Text tool where the object box (don't know that correct name of it) is clamped incorrectly to the vector text (introduced in X3 if I remember correctly). This greatly messes up all the alignment tools; if you center your text, it is not actually centered (see image below).
To recreate this:
1. Create a new image with a vector layer.
2. Add vector text via Text tool.
3. Apply changes.
4. Use Object Selection Tool to select the text (clearly will show a empty gap to the right of the text).
5. In the "position on canvas" box click center. The text will not align center.
Another problem it has is if you layer text that have differences strokes amounts. The text will not match up correctly when aligned (see image below).
To recreate this:
3. Apply changes.
4. Copy and paste text as a vector.
5. Edit the stroke width of the lower level text.
6. Use Object Selection Tool to select both text objects.
7. In the "position on canvas" box click center. The text will not align center nor with each other.
Another bug I have found is the crop tool menu. Instead of being attached to the upper tool bar it is attached to the image; on small images it doesn't show up (see image below).
To recreate this:
1. Create a new image 100x100 pixels.
2. Click the crop tool. No tool bar.
If anyone knows how to fix these or a good work around, please let me know.
Simone Corel UK
Alludo
@zenxtang
The text tool problem has been logged as bug in X3 and X4, but can't be solved in X4 unfortunately.
The crop tool behaviour isn't a bug. In the smaller image, your document is just as small as the image itself with no workspace. Please make it wider as in my screenshot
qsabe
motherboard: ASUS P4C800-E
processor: Intel P4
ram: 3 gig
Video Card: ATI Radeon HD 4650
sound_card: Intel built in
Hard_Drive_Capacity: 200 gig
Monitor/Display Make & Model: Samsung 930B
Post by qsabe »
After X4 was installed I found clicking the paintbrush tool caused it to crash. I uninstalled the program, used the Corel cleanup tool to make sure it was completely removed. Ran the CCleaner to remove left in registry entries. Rebooted and now it won't instal saying another program is already installed. Any ideas.
Trouble fixed. First the new brushes are sensitive if you keep adding brushes as new versions of PSP comes out. The old red eye brush caused the crash when the brush ICON was selected.
The Corel PSPX4 cleanup tool didn't do it's job, so the registry had to be manually cleaned. That then allowed a new install.
Real pita but better than going to CS5..
Robolovsky
Does anyone know when the next service pack is due?
eL_PuSHeR
motherboard: Gigabyte MA790FX-DS5
processor: AMD Phenom 9600 X4 BE
ram: 4GB
Video Card: nVidia GeForce GTX 660Ti
sound_card: Sound Blaster Audigy
Hard_Drive_Capacity: 500GB
Monitor/Display Make & Model: BENQ G2222HDL
Post by eL_PuSHeR »
I was wondering just the same. I have got high hopes. I have been unable to use X4 since I bought it some months ago...
