PSPx4 Bugs and fixes.
Robolovsky
motherboard: ASUSTeK Computer INC. P7P55 LX Rev X.0x
processor: 2.95 gigahertz Intel Core i7 870
Video Card: NVIDIA GeForce GTS 450
sound_card: VIA High Definition Audio
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Iiyama PL2410HD
Re: PSP X4 Bugs and Fixes
Post by Robolovsky »
MarjV wrote:I wish that the most recent X4 update had included the traditional "mirror" and "flip".
The update deleted my fix so I had to apply it again. .
Marj
Flip vertical and horizontal can be found in the Image menu as before. I too mourn the loss of the Mirror option.
What is your "fix"?
ADonahoo
motherboard: Dell Inc. 0KWVT8 A03
processor: 3.60 gigahertz Intel Core i7-4790
ram: 24GB
Video Card: AMD Radeon R9 270
sound_card: Creative SB X-Fi Titanium
Hard_Drive_Capacity: 13256GB
Monitor/Display Make & Model: Dell SX2210 and Dell ST2210
Corel programs: PSP X7, X8, X9, 2018, 2019
Post by ADonahoo »
Marj
What is your "fix"?
Reloading my saved workspace got back my home-made mirror and flip commands. The fix is to open an older version of PSP and record a script using each of the original mirror and flip commands. Save them with a descriptive name (I called my mirror_layer and flip_layer) then bind them to an icon and add them to the image menu. I also added a keyboard shortcut for each one. I actually like the new mirror and flip commands, just wish Corel had added them as additional commands instead of the replacing the commands we have used for years. I can't believe someone in charge thought that was a good idea.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Re: PSPx4 Bugs and fixes.
Post by hartpaul »
Actually I don't mind the X4 set up the two Flips bring together the same type of action, but one horizontally and one vertically.
It presents a consistency of terms which makes it simpler for anyone new learning the program. Other programs seem to look for more exotic names to do the simple actions we have in PSP so you finish with a plethora of odd names in diferent programs for the same action. Just look at the warp brush for one.
I do note that in PSP8 they had small icons beside the words to show what the action was as well perhaps that could be rejuvenate to make it easier as well.
df
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Post by df »
To get your icons back click View> Customize...
With the Customize window open go back to the workspace and click the Image group (or menu item or whatever you want to call it). When the menu opens right click what you want to have an icon next to and click Image and Text, rather than just Text. Repeat this with the hundred or so functions that you'd like an icon for. Now you're having fun eh :roll: :roll: :roll:
Regards, Dan
Robolovsky
Robolovsky wrote:Applying the SP2 update has stopped the continual cataloguing. Very grateful for that. I suspect that X4 was simply not storing the calalogue file at all.
I take this back. It now appears that the catloguing happens if you start up in edit mode with the Collections tab active in the navigation panel. It does not happen if the Computer tab is active. Ho hum! :o
ermel
System_Drive: G
motherboard: Asus M4A79 Deluxe
processor: AMD Phenom II X4 955 3.2 Ghz
ram: 4.0 GB
Video Card: GeForce 9500 GT 512MB
sound_card: Auzen X-Fi Prelude 7.1
Hard_Drive_Capacity: 1 Tetrabyt
Monitor/Display Make & Model: Dell E207 WFP 1280 x 1024@60 Hz
Post by ermel »
My personal experience is the following: PSPx4 was working fine, until I registered it. Now, it crashes and does not act as normal, can't detect contents of "computer", only "Desktop".
I bought a valid legal copy and have valid S/N.
I will re-install and try to use it for a while, to see if works satisfactory, if not then I will be going back to Photoshop!
What a loss! Corel wake up, if this keeps up your sales will drop to almost nothing!
Babble
motherboard: ASUS M4A78T-E
processor: AMD Phenom II X4 945 3GHz
ram: 8 GB
Video Card: XFX Radeon HD6750
sound_card: Via HD sound
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Asus PA238Q
Post by Babble »
I think this is a bug I just found. When I apply the Effects > Textures Effects > Tiles (and set angularity high like 75) to an image, it works. When applied to a new raster layer above the image filled with straight color (light gray for example) it only produces hexagons, squares or triangles even though the settings are the same as for the image. If I use a gradient on the layer, it works as it does with an image. This should work the same with straight color.
Its possible that it is designed to look for contrast but it seems odd and should at least have a click on/off box.
digitalpix4all
motherboard: Intel
processor: Intel I7
ram: 10GB
Post by digitalpix4all »
Downloaded and installed PSP 4 Trial from the Corel download page. It takes ~20 seconds to complete loading on an I7 machine w/10GB of RAM. X3 is junk!! X2 loads immediately. Guess I'll stick with X2.
BTW, tried to install PSP X4 twice with thew same results.
JCA
processor: Intel Core i7 2630QM 20GHz
Video Card: GeForce GTX 560M 3GB
sound_card: Sound Blaster X-Fi HD
Hard_Drive_Capacity: +2TB
Post by JCA »
In PSP X3 I can Repeat an action to multiple layers.
In PSP X4 I can Repeat a selection update (selecting another layer)! I do NOT need to Repeat a selection update! Repeat has become almost useless in X4. I can Repeat the same action multiple times on the same layer, I can Repeat the same action on multiple images. More often I need to Repeat the same action on the same image on multiple layers! If I want to Repeat the same action on multiple images, I use the batch process with a script!
ADonahoo
ram: 24GB
Post by ADonahoo »
JCA wrote:In PSP X3 I can Repeat an action to multiple layers.
This was fixed in X5, never in X4. I've uninstalled X4, too broken.
JCA
Post by JCA »
Good to know that was fixed.
Some other issue I'm having randomly... When I save an image, sometimes the filename gets a bunch of japanese/chinese kanji symbols added after the original name and before the file type extension. Seems quite strange.
vee
motherboard: MEDIONPC MS-7658 1.0
processor: 3.20 gigahertz Intel Core i5 65064 kilobyte primar
ram: 4.00GB
Video Card: TEO TL765
Hard_Drive_Capacity: N-A
Monitor/Display Make & Model: Relisys TEO TL765 (17.1"vis, s/
Post by vee »
I am using PSPX4 Ultimate , and apart from the docking station not working properly ,
everything was okish , until a few days ago and a update came in .
Then I lost the lot ... I tried a repair , downloaded the file that was sent to me for languages and got it into the right file .
Went back to it the next day to find that all the work I had done the day before was lost .
It seems that Alkami the Net session Interface , had gone wrong and on top of that the Patch was for a Mac computer :roll:
I use Internet Explorer 8, and have Windows 7 .
I have Re installed the programme , and have been adding Tubes (what I have left of them ) Gradients Patterns and Masks ,
a lot of them I have made myself , especially the backgrounds for Patterns .
I started using Corel PSP X2 Ultimate , a few years ago , so have a fair bit of stuff that I have made and used myself ,
I am in another forum with someone who has the same programme and the same thing happen to her some time back .
Being disabled etc Blah blah ..... I refuse to upgrade anymore and if needs be will go back to X 2
Has any one else had this happen to them ? and any advice would be extremely welcome
as I at the stage of throwing both programme and computer outta the Window ,
and can now understand why my friend said she nearly had a breakdown over it all . :roll: :x :)
By the way Hiya folks :)
pinobot
motherboard: Asrock Z77 PRO4-M
processor: Xeon 1230V2
ram: 16 GB
Video Card: ASUS GTX660 TOP
sound_card: Realtec ALC892
Hard_Drive_Capacity: 250GB+4TB
Monitor/Display Make & Model: Samsung Synchmaster 2343 BW
Post by pinobot »
If i use 'Unsharp Mask' the sharpening happends in two steps every time i tab the box 'preview on Image' but when i use the preview boxes and i press 'Preview on Image' the effect is instant.
Kind of anoying because it makes it harder to Judge the difference.
It also happends with other effects that use the two preview boxes.
LindaSue
motherboard: Gigabyte
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Post by LindaSue »
pinobot wrote:If i use 'Unsharp Mask' the sharpening happends in two steps every time i tab the box 'preview on Image' but when i use the preview boxes and i press 'Preview on Image' the effect is instant.
What do you mean by "two steps"? I almost always keep "Preview on image" checked for most effects/tools and I see the result on my image right away.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
pinobot
ram: 16 GB
Post by pinobot »
It's when you see the two boxes and you press "Preview on Image" multiple times to see the difference.
