Can I have two PSP versions installed?
eL_PuSHeR
- motherboard: Gigabyte MA790FX-DS5
- processor: AMD Phenom 9600 X4 BE
- ram: 4GB
- Video Card: nVidia GeForce GTX 660Ti
- sound_card: Sound Blaster Audigy
- Hard_Drive_Capacity: 500GB
- Monitor/Display Make & Model: BENQ G2222HDL
Hello.
Although PSP X4 is failing on me due to TIFF file saving issues, I wonder if it possible to have both PSPP X3 and X4 installed at the same time?
If so, I could use X4 for everything except saving TIFFs.
Best regards.
Best regards.
eL_PuSHeR
- ram: 4GB
Re: Can I have two PSP versions installed?
Great.
I will do that this afternoon.
Best regards.
Best regards.
pdxrjt
- processor: Intel Core i7 - 4.2 GHz
- ram: 32 GB
- Video Card: NVIDIA GeForce GTX 1080
- Hard_Drive_Capacity: 10TB Int.
- Monitor/Display Make & Model: Acer 32 inch x2
- Corel programs: Paint Shop Pro 2018
No problems here with both.
Adverts for Corel products when you close PSP don't bother me.
eL_PuSHeR
- ram: 4GB
Yes. Tried it and both X3 and X4 can coexist peacefully.
Dizzie
- motherboard: dunno
- processor: dunno
- ram: 6 GB
- Video Card: dunno
- sound_card: dunno
I have Versions 7, 8, 9, 10, 13, & 14 all installed. I have had as many as 3 open at the same time...might could have them all open, dunno, haven't tried it.
eL_PuSHeR
- ram: 4GB
I have found out that when having both X3 and X4 installed, X3 workspace custom settings are reverted back to defaults after using X4. Not a great deal though.
Dizzie
- processor: dunno
- ram: 6 GB
- Video Card: dunno
- sound_card: dunno
pretty odd...mine doesn't do that.
eL_PuSHeR
- ram: 4GB
Hmm. Maybe it's just a glitch on my PC.
wds937
- motherboard: Dell 0HN7XN A01
- processor: Intel Pentium Dual Core E5800 - 64-bit - 3.20 GHz
- ram: 4 GB
- Video Card: Intel G41 Express - integrated
- sound_card: Realtek High Definition Audio - integrated
- Hard_Drive_Capacity: 320 GB
- Monitor/Display Make & Model: ASUS VS247
You probably could. I have 8, 9, X, XI, X2, X3, and X4 all installed on this same machine, and I can open all of them (or any combination) at the same time. One small issue you may encounter is that, depending on your Windows 7 color scheme, you may have Windows tell you that PSP 9 and PSP X are incompatible with that color scheme, and then Windows will revert to a "standard" color scheme for all applications; it will switch back once you close PSP 9 and/or PSP X. Obviously, all of those versions of PSP open at the same time will use a lot of memory, so that may limit what you can do, how large your images are that can be edited, etc.Dizzie wrote:I have Versions 7, 8, 9, 10, 13, & 14 all installed. I have had as many as 3 open at the same time...might could have them all open, dunno, haven't tried it.
Dizzie
- processor: dunno
- ram: 6 GB
- Video Card: dunno
- sound_card: dunno
That brings me to a question I was wondering this morning. I have PSPX installed on Windows 7 32-bit with Aero Theme and it runs just fine. Then I have PSPX installed on Windows 7 64-bit with Aero Theme and it gives that "The color scheme has been changed to windows basic" message and I can't figure out why....any ideas?
eL_PuSHeR
- ram: 4GB
Maybe you need updated video drivers for that machine. Are they updated?
Tim Morrison
- Moderator
- motherboard: Asus P4533
- processor: 3.16 GHz
- ram: 2GB
- Video Card: Radeon HD4650
- Hard_Drive_Capacity: 2.6 TB
- Monitor/Display Make & Model: HP LP2275W
Are both versions updated to 10.10?
Only 10.10 supports Aero... not entirely sure about 64 bit though.
Tim Morrison
C-Tech Volunteer
C-Tech Volunteer
Dizzie
- processor: dunno
- ram: 6 GB
- Video Card: dunno
- sound_card: dunno
The 32-bit pc where it works fine, is 3 years old. The 64-bit pc where it doesn't, is 3 weeks old. I wouldn't think I need to update the video drivers on a brand new machine.
Thank you so much Tim, that is exactly what it was....I hadn't installed the last patch. I found the CD it was on and installed it and now it works great. Thanks so much. I know it was not a problem, but it was definitely annoying.
wds937
- ram: 4 GB
Hmmm, maybe I missed a patch or two from when I installed all my stuff on this computer after my previous one died. My PSP X displays as 10.02. I guess I'll have to do a little updating.Tim Morrison wrote:Are both versions updated to 10.10?
Only 10.10 supports Aero... .
