Re: can't open saved vsp file after reinstall window
I've just reinstalled my window xp which I used it before, but as the result, I couldn't open my saved vsp file at Corel Videostudio pro( I used same software to edit my video), screen say:"file format is not valid" and error no. is 15055:1:1, also I couldn't import my video file of the project to the library, shows: unable to open the file , file not found and I couldn't see all my files' format(such as video, audio etc) in the smart packaged folder. BUT I can still import the video files which I have never used, can anyone kindly help? millions thanks in advance.
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Re: Re: can't open saved vsp file after reinstall window
Can you tell me what version Videostudio did you use to create or save the .vsp that you cannot open and the file format that you cannot insert in the library?
You need to use the same or newer version of VS in order to open the .vsp that you created. You may also want to make sure that you have all the codec installed on your computer, specially that you are using Windows XP. Here are some of the codecs that you may want to install.
RealPlayer: http://www.real.com/
DivX: http://www.divx.com/en/software/divx-plus/codec-pack
XviD: http://downloads.xvid.org/downloads/xvidcore-1.3.2.zip
Windows Media Player: http://windows.microsoft.com/en-US/wind ... dia-player or just download the Windows Encoder at http://www.microsoft.com/expression/pro ... rview.aspx
QuickTime: http://www.apple.com/quicktime/download/
Direct X: http://on-msn.com/aLrk0j (WinXP)
Direct X: http://www.microsoft.com/Windows/window ... tx-11.aspx
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
