proDAD Mercalli SE SD video?
alanball
motherboard: Gigabyte Technology B450M H
processor: AMD Ryzen 5 3600 6-Core
ram: 16 GB
Video Card: NVIDIA GeForce GTX 1660 SUPER
Hard_Drive_Capacity: 2TB+480SSD
Monitor/Display Make & Model: ASUS VN247
Corel programs: VS10, VS2018 Ultimate, VS2021 Ultimate
Post by alanball »
Hi all, being way behind the tiime and still using SD video I was wondering if anyone has used proDAD Mercalli SE with SD video and if so what reults they got. With the special on at the moment I would consider bying although I was very put out when the Ultimate version came out a couple of months after buying Pro X4. I suppose X5 may be on the way but it may not have these specials included.
Alan Ball
GLOBETROTTER
processor: PC and Laptop
ram: 3GB
Hard_Drive_Capacity: 1.5TBR
Monitor/Display Make & Model: ATi
Re: proDAD Mercalli SE SD video?
Post by GLOBETROTTER »
Yes, I've just launched another new DVD and some of the footage was helped with a little adjustment using Prodad. You can use it on SD, or as I did, use it on the HD clips, and then save to HDV for editing, before finally being made into high quality SD for professional DVD production. VSX4 is well worth buying, because the Prodad costs more if purchased seperately.
alanball
ram: 16 GB
Post by alanball »
Thanks GLOBETROTTER for your comments and getting back to me, much appreciated.
Alan Ball
TheListener
processor: Intel Core i7-7500U CPU 2.70GHz
Video Card: Intel HD Graphics 620
Hard_Drive_Capacity: 256GB
Corel programs: VideoStudio 2018 Ultimate
Post by TheListener »
I have started using Mercalli in VSPX4 Ultimate and like what I see in the preview window. However, when I burn a DVD, the "Have to replay to analyze" (or some similar wording) shows up on the final DVD and the video image is grayed. When I go back to the video clip with Mercalli on it, when I bring it up, it doesn't think that it needs to be rerun, and I can't force it. I'm imaging that when running the analysis in the editor that the result is stored. However, I supposed that come re-rendering time at burn time (HD .mov to SD DVD) that it would just redo any re-analysis for the clip during the burn process. Well, it doesn't seem to be doing this. What am I missing? New VSPX4 user, by-the-way. Thanks.
Kingston
motherboard: Gateway [Acer] DX4860
processor: Intel Core i5 3rd gen. 3 GHz
ram: 8 GB
Video Card: Intel HD 2500
sound_card: Bluetooth
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Dell ST2210; Samsung SmartTV 3D 40"
Post by Kingston »
To see if Mercalli needs to analyze your clip, make sure you select "Project" and not the "Clip" option that is just below the preview window. When in "Clip" view, the message that Mercalli needs to analyze won't be displayed.
If you see the message that analysis needs to be performed, go to the Attribute options tab, select the Mercalli filter, click "Customize Filter" button, and then click the "analyze" button again.
TheListener
I tried what you suggested, but nowhere/nohow will the clip on the DVD with the "needs analysis" show again for the clip in VSPX4. This has now happened on both DVD and BR burning. There must be something wrong with my workflow. I expect to put the Mercalli filter on the clip once, run the analysis once, then forget about it. This isn't working for me. I haven't needed to enable smart proxy. And I'm using HW acceleration for encode and decode. Do I go to Corel or Mercalli with this problem?
Kingston
ram: 8 GB
Post by Kingston »
After you ran the analysis on the clip, did you do any kind of editing? If you split the clip afterwards, for example, I believe you need to run the analysis again on each part.
I would try to get help from Corel.
GLOBETROTTER
ram: 3GB
For an explanation of how I like to work with proDAD, please click on this link to an earlier Corel web board post:
http://forum.corel.com/EN/viewtopic.php?f=1&t=43847
TheListener
New info. When I render my project to a file, the Mercalli clip is copacetic. It appears that the render direct to DVD or BR path is broken (from my perspective). Does Corel monitor this forum for bug reports? And yes, I think I'll create deshaken clips before including them into my VSPX4 projects from here on out. Thanks!
GLOBETROTTER
ram: 3GB
'TheListener' - Please re-read my earlier post. You cannot render the Prodad adjusted video clip direct to DVD from the timeline unless you have rendered it into a new file first.
TheListener
GT,
Right. I got the part about your workflow rendering to a file first. But I didn't understand you to say that going direct to disk was well understood to not work. If it is well understood, I still don't know how one would know that. If not, I hope someone would fix this as a bug, or figure out how to communicate this limitation to the user more clearly. Thanks!
erdna
motherboard: Gigsbyte H81M
processor: I7 4770
ram: 16GB DDR3
Video Card: Intel HD4600
sound_card: Intel display audio
Hard_Drive_Capacity: 1TB 7200rp
Monitor/Display Make & Model: Panasonic TX32cx600e
Post by erdna »
After trying the proDaD plugin in X3 (with te red cross..) I bought VSX4 Ultimate (download version) and after uninstalling my proDaD 2.0 trial version I installed VSX4 Ultimate +bonus +SP2, because it should include proDaD SE. But no proDaD in the FX library. Where can I find proDad SE in VSX4 Ultimate?
Kingston
ram: 8 GB
Post by Kingston »
TheListener:
In VideoStudio if you apply Mercalli to a video clip that is progressive, then you need to share to a progressive format. If instead you share to a video format that is interlaced (TFF/BFF) such as DV or DVD-MPEG-2, then the message will appear on your shared clip.
Going from interlaced to progressive doesn't seem to be a problem, yet. I say "yet" because I haven't tried every possible combination. If you have an interlaced clip such as DV-AVI and stabilize it with Mercalli, you can share to either progressive or interlaced video formats without the message appearing.
See if you find the same thing.
TheListener
I've gone from 1920x1080p h.264 source, to Blu-Ray H.264 (1020x1080p) .m2t files, to using these in Blu-Ray disc burning and DVD disc burning, to good result. None of the Mercalli filters show the "re-run analysis" overlay. But I haven't gone to an interlaced format, so I can neither confirm nor deny your observation about the Mercalli progressive to interlaced path being problematic.
Peem
motherboard: Belarc does not use term motherboardTOSHIBA Satell
processor: 2-40
Video Card: Intel R HD Graphics 4600
sound_card: NVIDIA GeForce GT 740M
Monitor/Display Make & Model: Generic PnP Monitor (17.6"vis, December 2011
Corel programs: VS 2021 Ultimate, Paintshop pro
Post by Peem »
I have followed a few threads to get to here, trying to get rid of the message in my rendered video file telling me about the need to reanalyze the clip. I started with a MOV file which I can only assume is progressive [‘properties did not mention progressive or interlaced ‘] and did solve the problem by rendering the ‘mercalli-ised’ clip to a HDV format with a ‘p’ at the end.
Further back in the thread [or was it another] it mentioned clicking on ‘customize filter’ then clicking on ‘analyze’ to see if the clip needed reanalyzing. I cannot find an ‘analyze’ button in that window and wonder if it had disappeared from the X5 version?
Regards, Peter
