Where are the menu templates in X4?
david1939
motherboard: Unknown
Hard_Drive_Capacity: 465GB
Corel programs: VS ultimate 2023,MotionStudio 3D
Post by david1939 »
I just upgraded from X3 to X4 (can't beat Corel's recent $29.99 offer!, probably means X5 is on the way...). When I upgraded to X3, I had some "My Favorites" DVD menu templates in VS10+ which I managed to transfer to MovieFactory SE by moving some files (*.ufo?) from some VS10 directory to somewhere in MovieFactory. It's too long ago -- can't remember the details. I'm puzzled whether I can move them into X4, the question is: where?
SONY DCR-HC42 Handycam, VideoStudio X4 Pro, X5 Pro, X6 Pro, Motion Studio 3D
Re: Where are the menu templates in X4?
Post by BrianCee »
Menu templates for X4 are stored in - C\Documents and settings\*username*\Documents\Corel VideoStudio Pro\14.0\Favorites\4x3 (or 16x9)\Favorites
you can transfer the template files from previous versions into there - they are indeed .ufo files - if there is also an .MS file in the original folder with the same name as the .ufo file then that must be transferred as well remember to transfer into the correct format folder 4x3 or 16x9. Templates without an .MS partner may not work in X4.
Note that you must close and re-open VideoStudio to see any new templates which will appear under the 'favorites' tab on the gallery
david1939
Post by david1939 »
Hmmm... The folder .../Documents/Corel VideoStudio Pro/14.0 only contains two folders: DMF_TEMP and SmartProxy. Should I create a folder "Favorites/4x3" in which to put the files?
david1939
Post by david1939 »
Just answered my own question. I created a favorite menu in X4 and that created the set of folders and files. Thanks!
