Lifting Bamboo Pen Stops Painting
Rikev
Post by Rikev »
Hello, I have a Wacom Bamboo Pen and Touch on Windows 7 64-bit and it appears to work fine in Windows on the desktop and in MS Paint. I can drag a box on the desktop, scribble in paint to my heart's delight, etc.
In PSP X4 the pen works...briefly. If I keep the pen down enough to make the red light appear on the tablet (to say it has detected the pen is close) it will happily draw in freehand with the paint/airbrush. If I lift the pen high enough to go out of detection range and put it back on the pad, PSP won't paint. The mouse will paint and the pen will work with tools like Pen or Flood Fill and in other apps but freehand doesn't work.
To get freehand back, I need to click on a button, tick box or other window control on the screen with the mouse. Then I can draw freehand again until the pen goes too high.
The PSP when it goes wrong like this is strange. Hovering the pen within detection range moves the cursor as normal, but on pressing down the 'dot' (or circle depending on brush size) stays where it is without making a stroke. The cursor moves around normally otherwise without applying anything to the image.
I've tried to re-install the drivers with a new copy from the manufacturer's site and removed Windows Tablet Support but nothing works to resolve this.
Any ideas please? :)
brucet
operating_system: Windows 8.1
Re: Lifting Bamboo Pen Stops Painting
Post by brucet »
Mine has also been acting 'strange'. I found the issue was in the Brush Variances. Set them back to 'Normal' and see if that makes a difference. (Some tools work ok while other did'nt respond at all). It seems PSPx4 has some difficulty with detecting pressure sensitivity. Set on 'Normal' they seem to all work ok.
Rikev
Post by Rikev »
Ahh thanks for the help. That has fixed the lifting problem, though the pressure sensitivity doesn't work at all now.
brucet
Post by brucet »
I've never been a fan of the pressure sensitivity so I don't miss it. You may find that the pen is actually working. I found that by increasing the pen size I could get the sensitivity to work. But you may need a setting of 50 if you want a pen size of around 10. It's a pain doing it this way but the pressure feature will then work.
Rikev
Post by Rikev »
Bruce you are a star, thanks for the help. I am a total rookie to this field. :)
billrey
ram: 4gb
Post by billrey »
Just to piggyback on this post. Changingthe Brush Variance to Normal works with Win XP Pro and PSP X2 and PSP X4 also.
hamcraft
Post by hamcraft »
But this is only a band-aid solution.
I have the same problem with PSP X3 and a Wacom Bamboo Capture, but I want to use pressure sensitivity in PSP X3. What is the root cause of the issue??? Is it PSP or is it the Wacom drivers?
B4b5
Post by B4b5 »
hamcraft wrote:But this is only a band-aid solution.
I've been following this trying to solve the same problem with Win7, x4, & Wacom Graphire4.
Now that I've done this---> http://forum.corel.com/EN/viewtopic.php ... 09#p240909 <--- this one is one update back from the most recent driver update.
My Graphire4 pen & tablet work very well with PSP-X4.
Now all of the Brush Variances also work and I finally see the usefulness of the Wacom tablet.
hamcraft
Post by hamcraft »
I wish it wasn't so hard to find the legacy drivers that work with the Capture and Create.
I reported the issue to Wacom... Hopefully between Corel and Wacom the problem gets addressed...
B4b5
Post by B4b5 »
hamcraft wrote:I wish it wasn't so hard to find the legacy drivers
This Wacom site might help---> http://www.wacom.eu/index2.asp?pid=29&lang=en <--- Searchable Driver lists...
hamcraft
Post by hamcraft »
Thanks B4b5, but unfortunately since I have a new Gen3 tablet (Bamboo Connect/Capture/Create) there is no functioning legacy driver available for me to roll back to.
See also this thread on Wacom's forum: http://forum.wacom.eu/viewtopic.php?f=7&t=8485
B4b5
Post by B4b5 »
hamcraft wrote:See also this thread on Wacom's forum: http://forum.wacom.eu/viewtopic.php?f=7&t=8485
It really is a Swamp!
hamcraft
Post by hamcraft »
Oh it gets better. I used Corel's tech support ticketing system to make sure they are aware of the issue. Maybe I went about it the wrong way, but this was the ultimate response:
Due to the complexity of the issue that you have reported, it is best that you speak to one of our level 2 technicians as I do not have enough resources to research further on this. You will need to have a Corel protection plan so a technician can call you and resolve this issue. Please call for more information about this.
So wait, I gotta pay $$$ to submit a bug report? OK then, nevermind.
B4b5
Post by B4b5 »
hamcraft wrote:So wait, I gotta pay $$$ to submit a bug report? OK then, nevermind.
I too ran into this, only I was trying to figure out why SP1 wouldn't install.
Turns out it wouldn't install because it already was installed... (Newbies!) - It took another forum member to help me through that without $$$...
hamcraft
Post by hamcraft »
We apologize for the inconvenience that these may have caused. However, I will be reporting this issue/product defect to our product engineers so they can consider this for future updates on our program.
There we go. That was my goal. Just took some convincing.
