Using HDR in PSPP X4
KenBob2
- motherboard: Supermicro X7DA8+
- processor: Dual Intel Xeon E5410 2.33GHz
- Video Card: Radeon HD5830
- sound_card: RealTek
- Hard_Drive_Capacity: 2.3TB
- Monitor/Display Make & Model: Asus VH238 23"
A simple question: How do I convert an HDR file into a tiff file. I see no opportunity to save as a different type of file from one of the 6 default styles. Also how do you print one of the defaults, there seems to be no right clicks in the HDR adjustments panel.
brucet
Re: Using HDR in PSPP X4
I don't use PSPx4's HDR program. I use Photomatix as I think it gives far better results. (HDR and RAW are weak features of PSP IMHO).
Anyway here's what I know about HDR in PSPx4.
When you have finished with your HDR work click the 'Save and Close' button on the lower left. It will/should ask you where you want to save the file. Then, once saved, go to the 'Edit' tab in PSPx4 and open up the file. From there you can do a 'normal' save in whatever format you desire.
I hope this helps.
Someone else will come and tell us a simpler way!!!
I hope this helps.
kaymann
- motherboard: ASUS P8P67 PRO REV 3.1
- processor: Intel i-7 6800K
- ram: 32 GB
- Video Card: NVidia GeForce RTX 2060
- sound_card: Onboard
- Hard_Drive_Capacity: 3.5 T
- Monitor/Display Make & Model: MSI MAG 341CQ & Dell 2470
- Corel programs: PSP 2019 Ult, Painter 2020, CorelDraw X7
Or you could click on the "Edit" button which is right above the save and close instead, Then you can save as a .tiffbrucet wrote:When you have finished with your HDR work click the 'Save and Close' button on the lower left. It will/should ask you where you want to save the file. Then, once saved, go to the 'Edit' tab in PSPx4 and open up the file. From there you can do a 'normal' save in whatever format you desire.
KenBob2
brucet & kaymann,
Thanks for your help. I get it now; I was not completely processing the raw .hdr file to get to the point of the save & close
Cheers
Cheers
