probleme avec paint shop pro x4
cecille
Post by cecille »
Je parle francais et il n'y a aucun forum en francais...
j'ai acheté pspx4 et j'ai un problème avec image miroir et image retourné
je colle un tube a droite de mon canvas et je le duplique. par la suite je fais image miroir, la copie du tube devrait se rendre à gauche et non elle se met pardessus celle de droite mais a fait l'effet miroir
pouvez-vous m'aider
cecile
Re: probleme avec paint shop pro x4
Unfortunately, on this forum we only use English. So you will have to use a translation service like Google's since I am not always around
Malheureusement, dans ce forum on ne parle que l’anglais. Donc tu dois utiliser un service de traduction, comme celui de Google, car je ne suis pas toujours disponible.
For the benefit of our English-speaking users, here is my quick translation of the original query:
I only speak French and there's no French forum.
I bought PSP X4 and I have a problem with mirror and reversed [flipped?] images.
I insert a tube on the right hand side of my canvas and duplicate it. Then I make a mirror image. The tube copy should appear to the left, but it doesn't. It appears above the right hand tube but in mirror format.
Can you help me?
Cecile
Joelle
ram: 16 GB RAM
Hard_Drive_Capacity: 1TB
Post by Joelle »
Bonsoir Cecile,
Il ya un newsgroup français:
cnews.corel.com
corel.international.French.PaintShop
Joëlle
Traduit par Google :-)
Joëlle
(PSPX9 )
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Only French huh? Well I hope the sites Joelle pointed you to work if not you could try translating and following the horrible instructions I've printed below.
If you have X3 or earlier you can record a script that uses Mirror and Flip from those and then use those scripts inside of X4. X4 changed Flip Horizontal and Flip Vertical to be local transforms instead of global so they only take the actual area of the layer into account when performing the flip.
You can also record scripts of Flip Horizontal and Flip Vertical in X4 and then edit them in notepad or similar. You just need to change the "LocalTransform" parameter from "True" to "False" this will force the script to use the old Mirror and Flip methods.
