I have in my project a lot of video clip that I did a slip of the audio track.
If I need to delete one clip, by example in the middle of the project, the audio track corresponding is not deleted...and if I delete it manually, all the other audio track at right do not move to the left...so the audio track and the video clip are not sync anymore.
How can I correctly delete a part of my project?
Thanks,
Delete part of project
Re: Delete part of project
There is a process called Ripple Editing, basically it locks selected timelines to the top track.
I have to say it can be a little complicated when having lots of clips as it may ask that associated clips are also removed.
To the left of the timelines is a padlock, float the mouse over for tool tip. Enable Ripple Editing will make the timeline padlocks available.
For more info press F1 for Help and search for Ripple
If you need to move multiple clips use Shift + Click to select adjacent clips then drag.
Good luck
Good luck
