I upgraded from photo pro x3 ultimate to x4 ultimate. However, I have some plugins I use in X3, i.e like KPT Collection, Magic Bullet et cetera. I tried to reinstall my kpt collection, but it shows only in X3 (again) and not in X4.
Please tell me how I can move my plugins from x3 to x4!
Lupke
How to move plugins from X3 to X4
Re: How to move plugins from X3 to X4
I don’t have X3 so cannot compare the two versions.
Have you set the Plug-In file location for X4
Go to File – Preferences – File Location—select Plug-In and Add
You should also be able to install the plug-ins to this folder
C:\Program Files\Corel\Corel PaintShop Pro X4\Languages\EN\PlugIns
PSP should then be able to automatically locate the plug-in.
Filly
- motherboard: ACPI X64BITS- PC
- processor: AMD Phenom tm 11 X6 1090T Processor 3.20GHZ
- Hard_Drive_Capacity: 1TB 350GB
- Monitor/Display Make & Model: LG 23 INCH W253
You will find not plugin folder in C:\Program Files\Corel\Corel PaintShop Pro X4\Languages\EN\PlugIns.
why I don't know from memory I had to add one..
you shouldn't have to use that folder X4 can pick up plugins from any folder.
you don't want to overload the program..
I have mine on another drive..
Thank you Trevor,
It worked. All plugins are visible now, thank you.
Topic closed.
G
Topic closed.
G
