Autosave in X4
Filly
- motherboard: ACPI X64BITS- PC
- processor: AMD Phenom tm 11 X6 1090T Processor 3.20GHZ
- Hard_Drive_Capacity: 1TB 350GB
- Monitor/Display Make & Model: LG 23 INCH W253
Autosave in X4
Today my X4 crashed when I went to check temp files was nothing there..
I checked the autosave in preferences and the tick is for enable autosave in adjust..
where in adjust ..
In X2 if you have a crash all the temp files open..
am I missing something..Cheers
where in adjust ..
Joelle
- motherboard: Asus Prime B350M-A
- processor: AMD Ryzen 5 1500 Quad-Core
- ram: 16 GB RAM
- Video Card: NVidia GeForce GTX 1050
- Monitor/Display Make & Model: Samsung
- Corel programs: PaintShop Pro X9
Re: Autosave in X4
Filly wrote:Today my X4 crashed when I went to check temp files was nothing there..
where in adjust ..
X4 has Manage - Adjust - Edit.
You need to click on Adjust.
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
Filly
Re: Autosave in X4
That doesn't work I can't understand why Corel has used Adjust as autosave,,
Thanks Cheers
Thanks Cheers
Joelle
- ram: 16 GB RAM
Re: Autosave in X4
I don't use Manage or Adjust, so was not aware what was going on, but I now see what you mean.Filly wrote:That doesn't work I can't understand why Corel has used Adjust as autosave,,
Thanks Cheers
I clicked on Adjust, after saving my images (grrr) then File>Preferences>Autosave Settings. Then ticked the box for Autosave.
So far so good.
Went back to Edit and got the Improper Argument notification, so yes, that's not working.
It's a dumb system.
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
Re: Autosave in X4
Joelle -- how exactly did this Improper Argument message come up? I mean what did you do in Edit which caused it to appear. I ask because I think I followed what you did in Adjust, and then opened the saved image in Edit and made further adjustments, and saved those.Went back to Edit and got the Improper Argument notification
Joelle
- ram: 16 GB RAM
Re: Autosave in X4
I had 3 images open in Edit, then clicked on Adjust.Ken Berry wrote:Joelle -- how exactly did this Improper Argument message come up? I mean what did you do in Edit which caused it to appear. I ask because I think I followed what you did in Adjust, and then opened the saved image in Edit and made further adjustments, and saved those.Went back to Edit and got the Improper Argument notification
Edit asked if I wanted to save the images, I said 'no'.
Adjust popped up, showing the first image in My Pictures.
I clicked on File>Preferences>Autosave Settings.
Then clicked the box to save Autosave the setting and clicked OK.
Then went back to Edit (I never use Manage or Adjust, was only trying it for Filly
Adjust went completely blank/black, then generated the Improper Argument message.
I closed the program and re-opened it.
I didn't save anything in Adjust.
Joëlle
Later edit:
Have just tried it again.
When in Adjust, then clicking on Edit, the Adjust settings disappear, everything is blank, see attached.
Joëlle
(PSPX9 )
(PSPX9 )
Re: Autosave in X4
I followed your steps. Had three images open in Edit (which I also use by default). Went to Adjust, and those three images closed. As I have said in at least one other thread, the image that opened in Adjust was not the first image in My Pictures, but the last image open in Adjust (and it was not one of the three previously open in Edit).
I went to File > Preferences > Autosave Settings. I ticked the box 'Enable Autosave in the Adjust Workspace' and clicked the OK button. Then I went to Edit. As at least I expected, Adjust closed and Edit opened with the image selected in the Adjust workspace. No error or improper argument message.
So once again, I don't think I can replicate the problem.
Joelle
- ram: 16 GB RAM
Re: Autosave in X4
Thanks KenKen Berry wrote:I followed your steps. Had three images open in Edit (which I also use by default). Went to Adjust, and those three images closed. As I have said in at least one other thread, the image that opened in Adjust was not the first image in My Pictures, but the last image open in Adjust (and it was not one of the three previously open in Edit).
I don't know why it does that, but in my case it doesn't matter as I never use Adjust and was only trying to see if I could help Filly, when all this happened.
Without using Adjust, most things work ok
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
Kathy_9
- Hard_Drive_Capacity: 2TB
Re: Autosave in X4
Just a shot in the dark but I noticed both Filly and Joelle are on 64 bit systems and Ken is on 32 bit - maybe that's why.
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Re: Autosave in X4
@Joelle - Like Ken I cannot recreate the problem... whenever I try to switch from EDIT to ADJUST or vice versa there's an image open... so no pop up message for me. You may need to reinstall the program.
@Filly - AFAIK when you enable the AUTOSAVE on ADJUST tab it will also be the same setting on EDIT and MANAGE.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
teknisyan
- ram: 4 GB
Re: Autosave in X4
I'm on a 64-bit Windows 7 and it does not happen on my end.
Like reading blogs?
About Tech
About Sports
About Tech
About Sports
Filly
Re: Autosave in X4
Guys my problem is with the autosave not doing waht it is supposed to do..
After a crash you should be able to get your work back through Temp files
as you could in X2 not sure about X3.. why have it..
AutoPreserve the folder is in your Documents
there are no work in there..
Here is the error from my Temp folder path..
