Batch Renaming in X4
mesmith322
motherboard: AMD Corp. Guam Base Board Version
processor: 2.10 gigahertz AMD Athlon II P320 Dual-Core
ram: 6GB
Video Card: ATI Mobility Radeon HD 4200 Series
sound_card: Conexant SmartAudio HD
Hard_Drive_Capacity: 307.69 GB
Monitor/Display Make & Model: Generic PnP Monitor (15.7"vis)
Post by mesmith322 »
I am finding that if I select a range of files to rename that already have numbers at the end, say 1 - 12, it is changing the order of the files and seeing the files numbered 10 - 12 before the file numbered 2. I am pretty sure it didn't work this way in X3.
I don't have X3 installed any longer and hoping someone can verify this for me.
df
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Re: Batch Renaming in X4
Post by df »
Computers in general are famous for doing this. Programers have gotten pretty good at hiding it, but some don't. Basically the computer looks at the number that start the sequence. 11 compared to 9 for example shows two numbers, one starts with 1 and the other starts with 9. 1 comes before 9. Do/see/use the sequences starting with 1 first, then 2, then 3, etc....
The workaround is adding digits yourself. 11 vs 09 for example, 0 comes before 1 so start with the sequence that starts with 0. If you're using more than 99 images you'd need to start with 001, more than 999 and you'll need to start with 0001.
I don't know about X3 doing this with the rename tool (never used it to rename personally) but people have been dealing with this for decades.
Regards, Dan
mesmith322
ram: 6GB
df wrote:Computers in general are famous for doing this. Programers have gotten pretty good at hiding it, but some don't. Basically the computer looks at the number that start the sequence. 11 compared to 9 for example shows two numbers, one starts with 1 and the other starts with 9. 1 comes before 9. Do/see/use the sequences starting with 1 first, then 2, then 3, etc....
Yes, I know all of that.
The files are listed in the proper order in the folder on my computer but are being resorted by PSP before renaming. I am pretty sure the files were not resorted in X3 and want to verify that before claiming it as a bug.
jaxman43
motherboard: PEGATRON CORPORATION 2AC2 2.00
processor: 3.40 gigahertz Intel Core i7-2600
ram: 8 GB
Video Card: NVIDIA GeForce GT 520
Hard_Drive_Capacity: 3 TB
Monitor/Display Make & Model: HP 2311
Post by jaxman43 »
Just tested this, and X3 acts the same way as X4. So does X2U which is as far back as I can test. So it hasn't changed for the last three generations anyway.
mesmith322
ram: 6GB
jaxman43 wrote:Just tested this, and X3 acts the same way as X4. So does X2U which is as far back as I can test. So it hasn't changed for the last three generations anyway.
Thanks for checking this for me. Guess I've just been asleep at the wheel all this time.
