Not smooth picture when doing pan
KOBRA76
motherboard: Gigabyte
processor: 3.07 gigahertz Intel Pentium Dual-Core
ram: 2 GB DDR3
sound_card: VIA High Definition Audio
Hard_Drive_Capacity: 500GB
Post by KOBRA76 »
hi,what is the best way to render the canon mov files in corel pro x4?
in my first video i render :upload to web-you tube-mp4 hd,is this good?
tnx
Canon 550D,18-55 & 50mm Lenses
My You Tube Channel
http://www.youtube.com/user/HDMAN2012?feature=mhee
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Re: trevor i need help from you
Post by teknisyan »
Yes, I think that's sufficient enough. You can also create the HD file first then just upload the video later and upload it without using videoStudio.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
Post by Trevor Andrew »
Hi Kobra76
First I tried replying to your PM regarding the Canon D7 details, unfortunately the PM failed as did an E-mail.
I can only assume your e-mail address in your forum profile is corrupt, not working.
Can you please provide a working e-mail address.
Select the User Control Panel link (top left) Then from the Overview tab Edit account Settings—Email address
Your camera and Youtube
Looking at this sample on you tube (canon 550d film look test) shows the frame having additional black bars top and bottom. Similar to panorama-scope is the best I can describe it.
However I don’t know how you created this actual file.
Other samples seem to have the correct aspect
Your camera records to three different quality settings, 1920 x 1080, 1280 x 720 and 640 x 480. fps25
Can you provide details of the one you are using.?
When you convert any video you are best to keep the frame size, aspect ratio, frame order and frame rate the same as original.
Using 640 x 480 and you Upload to Youtube as 16:9 may cause the black borders.
The other two formats 1920x1080 and 1280x720 should be ok to use Upload to Youtube 16:9
Video Studio provides many standard templates, if these are not suitable then use Make Movie Templates Manager to create your own template.
KOBRA76
ram: 2 GB DDR3
Post by KOBRA76 »
hi trevor,The YouTube video I made specifically to be like that with a black line up and down because that i called it the film effect.
Ishot in 1920-1080 24FPS I just noticed that the video has flecks and no flow streaming, so I thought maybe it's because rendering but it can be also due to the card. I will update My e-mail soon
Thank you
My You Tube Channel
Re:Not smooth picture when doing pan
You may be best to use 25 fps rather than 24 fps (23.976) assuming you are using Pal.
Choosing Upload to Youtube will use 25fps 1280 x 720 effectively down-scaling the 1980 video
If this is your desired output then you may as well use the camera to record to these settings.
Choosing Share Create Video File Mpeg4 HD will use 30 fps. 1980 x 1080
Either option will add additional frames to your video, possibly noticeable during playback
VS doesn't do 24fps as a sandard template
You should use Make Movie Templates Manager to create a template compatible with the original video properties.
The option Share Create Video File –Same as First Video is not available to you as VS does not recognise the Mov H264 compression
The quality of the video look quite good, I don’t see any Flecks, maybe I don’t understand what you mean? As for Flow Streaming, if you mean it downloads as its playing, I have no problems.
The only quality issue would be the highlights (white areas) being over exposed (burnt out)
But decide whether you are gonna upload 1980 x 1080 or 1280 x 720.
KOBRA76
ram: 2 GB DDR3
Post by KOBRA76 »
hi,Every time I Shot in motion the picture is not smooth,there are some flecks, what may be the problem?
Render not good? Or need a special card for HD? It really bothers me.
The following video you can see what I mean, the time I do PAN from side to side the resolt is bad.
http://www.youtube.com/watch?v=ww0CR92E ... ideo_title
My You Tube Channel
Hi Kobra76
Thanks for the e-mail details
I have updated your account using your new e-mail address.
You should recieve reply notifications allowing you to respond.
I have also merged your post to this post allowing you to continue with your quality problems.
The other post has been locked just to stop confusion.
KOBRA76
ram: 2 GB DDR3
Re: Not smooth picture when doing pan
Post by KOBRA76 »
HI trevor can you tell me how i fix the "not smooth" picture when i shot "pan" from side to side?
the picture always not good you can see here first in the beginig ,i try the all modes of the canon 550d,1080p,720p.24pfs,25pfs and all the time i get the same resolts :cry:
My You Tube Channel
Hi Kobra
Sorry for missing your last reply, however we still need details of your original video files properties.
You give a list of all the types, which one are you intending to use.
As its for the internet, 1280 x 720 x 25 fps would be a good format at least to start with. You must use 25 fps
Now what are details of the final rendered video file, what are their properties.? what template are you choosing to render the project?
Before uploading the video to You Tube, place clip in the timeline, right click and select properties What are they?
KOBRA76
ram: 2 GB DDR3
Post by KOBRA76 »
hi trevor and tnx for replay
this are the file properties
file format:quick time movie files
movie size:1920-1080
attributes:24bits,1920-1080
total frames:290 frames
frame rate:23.976 frames
My You Tube Channel
Is there anything in the camera's internal menu which allows you to change from the 23.976 frame rate and 25 fps? I suspect the slight jerky movement in your pans might be the result of VS adding 1 frame per second, and this only becomes obvious when panning...
KOBRA76
ram: 2 GB DDR3
Post by KOBRA76 »
yes,i can change to 25 fps and i try it and the picture is the same not smooth when i doing pan,i dont know what to do,i saw many videos in youtube with this camera and they have very good ouality when they do pan,you can see in the clip what i mean
http://www.youtube.com/watch?v=DkqDcSyBtQE
My You Tube Channel
Yes, I had already seen the jerky motion in a variety of your clips, but the only thing I could think of was that it came from VS add an extra frame every second... Does the camera have any of its own video software? If so, how does that look with the panning shots? How does the original video look when played in the Quicktime player?
KOBRA76
ram: 2 GB DDR3
Post by KOBRA76 »
i think you right,with other programs like vlc,window media player the video is much more better with the pan.i try even in sony vegas and the video is smooth there ,so like you said the problem is in pro x4 :cry: so now what can i do to fix it? i love to edit only in corel i dont want other edit programs.
My You Tube Channel
Kobra you must set the camera to use 25 fps.
Do a new test recording, pan the camera, be steady, on a tripod would be best.
Then check the video properties to make sure they are correct.
Check the quality of this before you edit, use a media player Quicktime Player or VLC Player
Use Video Studio – Settings – Make Movie Templates Manager to create a Quicktime template to:-
QuickTime Movie Files
24 bits, 1920 x 1080, 25 fps
Frame-based
MPEG 4 Visual
50% Quality, 24 Key Frame Rate
None, 8.000 KHz, 8 bits, Stereo
The template will be available from Share Create Video File at the bottom of the list.
Use this to render your video, when complete check the quality. (use a media player Quicktime Player or VLC Player)
If you wish to try 1280 x 720 simply make a new template as above but use this frame size
