Pro Ex4 Multi Camera editing
kobot8
motherboard: Gigadyte GA-Z68P-DS3
processor: Intel i5 2500K 3.30
ram: 8 GB
Video Card: GeForce GTX 580
sound_card: on board
Hard_Drive_Capacity: 500 gb
Monitor/Display Make & Model: DAO 185SERIES D [Monitor] 18,5
Post by kobot8 »
Is there a way to edit using a multi camera "technique" ? ( having several videos sincronized with an audio track and just switching between the video tracks) or is there some way to do that ?
Re: Pro Ex4 Multi Camera editing
Post by Trevor Andrew »
Video Studio has one main video timeline and the possibility of 6 overlay tracks that can be used for a variety of clips, Videos Images etc.
There are two title tracks available and 5 sound tracks.
As you are asking I assume you have not downloaded the trial version.
kobot8
ram: 8 GB
Post by kobot8 »
Thanx Trevor, I'm familiar with the overlay , I was just wondering is there a way to do multicamera editing or not
Hmmmm
You place the video files in different overlay tracks.
Then cut the bits you don’t want and remove them, as you play the project the different tracks will be displayed.
kobot8
ram: 8 GB
Post by kobot8 »
wish it was that easy, when i cut a part of the first video the rest of the video moves ahead and doesn't leave empty area for the second video to show up, so the both video tracks remain overlapped
Cutting the video in the overlay track will keep the video clips in position.
If you need to cut both use two overlay tracks rather than using the top track.
kobot8
ram: 8 GB
Post by kobot8 »
thank you so much, THAT was what I was looking for, is there a way to have the video in normal size by default in the overlay tracks ?
Yes
Settings - Preferences - Edit Tab--Use Fit to Screen as default.................
kobot8
ram: 8 GB
Post by kobot8 »
Hello, may I ask is there a way to have the waveform displayed in the sound track? for synchronizing
thank you
Post by BrianCee »
If you change to 'Sound Mixer' view - then each track having audio will display it's waveform - unfortunately though it is much to small for accurate cutting/syncing although it does help a bit.
kobot8
ram: 8 GB
Post by kobot8 »
Thank you, that is exactly what I needed!
