X4 special dll to get FU working..
Filly
motherboard: ACPI X64BITS- PC
processor: AMD Phenom tm 11 X6 1090T Processor 3.20GHZ
Hard_Drive_Capacity: 1TB 350GB
Monitor/Display Make & Model: LG 23 INCH W253
Post by Filly »
Come on Corel share this dll with us..
read below this was sent to me today
(There is a solution to get Filters Unlimited working in PSP14
You need to install a certain dll. file.
It was shared yesterday in a payed group (they got the file from a teamworker of Corel)
I installed the dll and FU is working now)
It is unfair to hold this back from us loyal customers..
Cheers
Re: X4 special dll to get FU working..
Post by Trevor Andrew »
I have Googled Filters Unlimited and it appears that you have to pay for the software is not free.
Maybe at one time the software was free.
I doubt if Corel have the right to provide files to get the plug-in working.
If this dll has been provided by a Corel teamworker I would guess this is quite un-official.
If you purchased the product and I assume you have then contact Filters Unlimited for their support as their compatibility lists PSP, so it should work.
http://www.icnet.de/filters_unlimited/features.html
You should also contact Corel Support as I doubt any Corel employees will read your post.
I may however be misinterpreting the information and am willing to be corrected.
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Post by teknisyan »
Hello Filly,
Can you provide more information on the DLL that you are referring? So that if needed, I can report this to the development team and hopefully I can provide you the information needed to help fix your problem.
Cheers,
Abiel
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
Filly
Post by Filly »
Abiel have sent it to you privately I tried it in X3 didn't work
couldn't get into my plugins so had to do a reinstall
I am wondering if you could copy them same dll from X2..
would that work..
would be nice if Corel had the same for X3..Cheers
I have installed the demo version of FU and it shows in the Effects, only the demo so I cant apply the effects but it does seem to work without any additional DLL.
I suppose it may be an Operating System issue, I am running XP
I only have X4 so cannot compare with older versions.
How did you install the plug-in?
Filly
Post by Filly »
Trevor the full version is readily available are you in any psp groups..
I will see if I can sent it to you privately
not sure if it is allowed to send it through here..Cheers
Hi Filly
Thanks for providing the filter
I have been able to install the filter which is now working ok.
I did not have to modify the program in any way, I did not replace any DLL files.
Ok this is what I did.
Extracted the files from the Zip.
Running the Setup.exe created a few files within a new Filters Unlimited 2.0 folder.
Using XP I installed this to C:\Program Files\Corel\Corel PaintShop Pro X4\Languages\EN\PlugIns
But works just as well any location on the pc. I was able to run it from the desktop.
Open PSP
File -- Preferences-File Locations-plug-ins Add the location of the Filters Unlimited 2.0 folder. To this panel
So are you still having problems with the filter.?
Filly
Post by Filly »
Trevor you don't want to load up your X4 with too many plugins..
i don't have any in there.. I have seperate folders all over the place..
Yes all my problems are now solved..Cheers
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
Filly - are you saying that FU now works on raster layers in X4? For me it only works on background layers. How did you fix it? Thanks, Kathy
Filly
Post by Filly »
Kathy have written to you privately..Cheers
