VSPX4 Works but ends in Lock-Up
kaymann
- motherboard: ASUS P8P67 PRO REV 3.1
- processor: Intel i-7 6800K
- ram: 32 GB
- Video Card: NVidia GeForce RTX 2060
- sound_card: Onboard
- Hard_Drive_Capacity: 3.5 T
- Monitor/Display Make & Model: MSI MAG 341CQ & Dell 2470
- Corel programs: PSP 2019 Ult, Painter 2020, CorelDraw X7
Everthing works including the little clitch with chapters thing. I burn the DVD HD disc and a pop-up indicates there is an error but the disc actually burned perfectly... I try to create a HD MP4 and it sticks on 99% (literly forever) and I have to Cntl-Alt-Del to end VSPX4 but there in perfect condition is my MP4 file right where it is suposed to be... Yes I count my blessings that the end product is what I want but not exactly how I want VSPX4 to perfom.
Re: VSPX4 Works but ends in Lock-Up
What type of HD are you burning, a BluRay or AVCHD.
Does it happen every time?
Does it happen if creating a standard DVD.
If yes have you tried a different make of disc?
Did you convert the MP4 to these formats, Share Create Video File – BluRay/Avchd before burning the disc?
What version of Quicktime are you using? try updating to the latest version.
Saying that the convert process would have been complete by the time burning started?
Manually updating Direct X to the latest version has been known to cure some problems???
In three parts, download, run to extract files, run the DXSETUP.exe file.
Update X4 with any service pack available. As far as I know the Ultimate does not need the service pack.??
kaymann
- ram: 32 GB
trevor andrew wrote:Hi
Yes it happens everytime
I am only making standard DVD's
Yes three different kinds
Latest Quicktime
Manually updated to DIrect X
All serivce packs installed.
kaymann
- ram: 32 GB
Well Trevor looks like we are both out of ideas - at least I can burn my discs.
Thank you for your time and consideration in trying to resolve the issues.
Not out of ideas, just a little busy at the moment.
You say in the first post that you are burning a HD disc, then you say you are making a Standard DVD
Which type of DVD are you creating?
If you are creating a Standard DVD then why are you converting the video to mp4?
A standard DVD uses MPEG 2 type files.
If you are creating a HD disc then you should convert to MTS?????
Knowing the properties of the original video file will help in advising you on what settings to use for your renders?
Right click a file in the timeline and select properties, what are they?
Ps where are you in this big wide world, maybe your asleep whilst i'm awake?
kaymann
- ram: 32 GB
Sorry for the confusion - Whether I am burning a HD DVD or Standard DVD, VSPX4 will end in a very simple "Unspecified Error" Pop-up and then I click OK and VSPX4 is either gone or unfunctional... or if I am creating a MP4 file it will just freeze at 99%, and I will have to Ctrl Alt Del to get it shut down.
In other words anything on the share tab is likely to do it's job but crash VSPX4 on the handoff back.
Arizona!!!!!! High Temp Yesterday (92F - 33C)
Properties:
QT files
video
24bits 1920x1080
29.970 frames/sec
sound
16bit Little Endian
48.000 KHz 16 bits Stereo
Jpeg filess
RGB True Color 24bit
5184x3456
72 pixels/inch
52,488 kb
Properties:
QT files
video
24bits 1920x1080
29.970 frames/sec
sound
16bit Little Endian
Jpeg filess
5184x3456
72 pixels/inch
52,488 kb
Ok
To burn a Standard DVD first convert the project to Mpeg2
Share Create Video File DVD Video – 16:9 (providing the duration is under 60 minutes)
This will create a new compliant Mpeg2 file suitable for burning a standard DVD.
Start a new project—nothing in the timelines, Share Create Disc-DVD --Add video file.
Create the menu. Please use a Thumbnail template.
Burning a DVD Folder will save on discs, the Video TS folders can be played on the pc to check quality.
After hitting “Burn” the process should start with Convert Menu, if you see Convert Title then the video files are being converted, not required as you added a compliant video file.
Some settings or files are incorrect.
Does that process complete without problems.?
