Remove an object from video frames
ctscar190
Post by ctscar190 »
I have taken a short video of a man sitting at a table. There is no movement but the man is talking. A little bit of the microphone can be seen. I tried to take the video into Paintshop Pro X3 to remove this object with smart carver. Is there a way to edit this video so that unwanted objects can be removed from the frames. I have Paintshop Pro X3 on this computer, and PhotoImpact on another computer. Can either of these programs be used to remove objects from frames.? Thank you.
Re: Remove an object from video frames
Post by Trevor Andrew »
Assuming the camera is static, then take a Snapshot of a frame, preferably in Project Playback mode
1 / Using Paint Shop use the Clone Tool to remove the Mic.
2 / Using the Erase Tool remove the entire frame with the exception of the Cloned Mic area. Maybe feather the edges?
Most of the image now being transparent.
3 / Save as PNG
4 / Add image to overlay track, below the original video-- fit to screen
