Adobe RGB vs sRGB camera raw file which should I use?
George
processor: i5 M430
ram: 4 GB
Video Card: ATI radeon
Post by George »
I'm just starting and I noticed that when I open a Canon RAW file which was created in Adobe RGB colour space, Paintshop Pro X4 appears to convert it to sRGB. I am using Adobe RGB because I thought it had a wider colour space. Should I just be using sRGB? Perhaps a Canon user could help me out here. Thanks George
Smakar
motherboard: ASUS Crosshair Formula IV
processor: AMD Phenom II X6 1100T
Video Card: Radeon HD 5870
sound_card: Creative Soundblaster Fatality X-Fi Platinum
Hard_Drive_Capacity: 1090GB
Monitor/Display Make & Model: ASUS VH236
Re: Adobe RGB vs sRGB camera raw file which should I use?
Post by Smakar »
I am a novice Canon user (Rebel XS) and I was taught that, if possible, to use the Adobe RGB 1998 setting, which is what I set in both PSP X3 and now X4 (in X4, File --> Color Management --> Color Working Space). For some reason, both PSP and even Photoshop default to sRGB and the setting has to be changed.
And I am VERY happy with the results!
George
processor: i5 M430
ram: 4 GB
Post by George »
Thanks very much. I went to my photo lab and they basically said the same thing - shoot in Adobe RGB, but convert to jpeg in sRGB for their small printer and convert to jpeg in Adobe RGB for their poster size printer. Thanks for the tip about the default in X4 to sRGB, I think that is my problem. George
George
processor: i5 M430
ram: 4 GB
Post by George »
Still having trouble, when I do File - Colour Management - Colour Working Space my only two choices are sRGB Colour Space Profile and CNZ005. How do I get to Adobe RGB? George
JStanley
Post by JStanley »
deleted
George
processor: i5 M430
ram: 4 GB
Post by George »
Thanks a lot. :D George
df
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Post by df »
Not only do printers typically print well using sRGB, most pro printing services convert whatever you give them to sRGB. Also the vast majority of web browsers do not suppport Adobe RGB. So if you want to display or print your images you'll likely want to convert your aRGB to sRGB. Unfortunately neither PSP nor Canon's DPP make it particularly easy to do that (don't know about Photoshop).
Regards, Dan
JStanley
Post by JStanley »
deleted
Tim Morrison
Moderator
motherboard: Asus P4533
processor: 3.16 GHz
ram: 2GB
Video Card: Radeon HD4650
Hard_Drive_Capacity: 2.6 TB
Monitor/Display Make & Model: HP LP2275W
Post by Tim Morrison »
George wrote:Hi
I'm just starting and I noticed that when I open a Canon RAW file which was created in Adobe RGB colour space...
Strictly speaking, your Canon raw file doesn't have a colour space (except in the little thumbnail that is included). A raw file is just a record of the output of the image sensor's elements, which isn't in any particular colour space, just as it doesn't have a colour temperature or a resolution, and isn't an image.
As well as the sensor information a digital camera raw file contains metadata. This extra data records the camera settings - like colour space and colour temperature - in a few bytes that is usually contained in the header area of the file. When you convert the raw data to an image (in a good raw converter) the conversion uses this metadata to determine the look of the image.
But it doesn't matter what you have set for the colour space... the raw data is exactly the same. Likewise, it doesn't matter if you choose another colour space later in the raw converter, because the image produced will reflect whatever you choose, whether it is the default recorded at the time you took the photo, or another colour space you choose later.
If you have Adobe RGB selected in the camera, then change it to sRGB in the raw converter, the image produced will be identical to one made from a raw capture that had sRGB recorded in the file's metadata.
Tim Morrison
C-Tech Volunteer
