Clickable links?
wezcorel
motherboard: ASUSTeK Computer INC. M2N68-AM Plus Rev X.0x
processor: 2.80 gigahertz AMD Phenom II X4 925
ram: 4GB
Video Card: NVIDIA GeForce 7025
Hard_Drive_Capacity: 3TB
Monitor/Display Make & Model: ASUS VH198
Clickable links?
Post by wezcorel »
New Pro 4X user here (only started using 6 days ago!). Love the software.
I have two questions. I checked the knowledge-base, youtube and searched this forum for answers.
Q1. Is it possible to embed clickable links in a video?
Q2. Is it possible to change the background colour of the pre-set Titles (the black background)? If so, how?
Thanks, Wez.
Re: Clickable links?
Post by Trevor Andrew »
Hi Wez
And welcome to the forums
No you cannot create links within the video.
The title background will be black when viewing from the library, once inserted to the timeline the video placed above will become the background, (drag the title to the timeline)
However you can change the background colour of the preview window, is useful to identify the actual frame area.
Go to (F6) Settings Preferences-General tab—background colour.
Also change Clip Display Mode to Thumbnail only, will show the timeline video frames in full.
Then check out the default settings on the edit tab
wezcorel
ram: 4GB
Post by wezcorel »
thanks for your answers Trevor.
About the black titles: the idea was to use one as an opening scene, so if I don't want the video to be the backdrop but instead have just text on a plain colour (e.g. changing black to pink for example) is that possible?
Wez
Post by BrianCee »
Yes - in that case you just drag a colour block down from the 'color library' and insert that in the video track and set it's length to your requirements.
You can also use a photograph or image such as a logo or pattern you like.
wezcorel
ram: 4GB
Post by wezcorel »
trevor andrew wrote:Hi Wez
Thanks for the tips Trevor!
wezcorel
ram: 4GB
Post by wezcorel »
BrianCee wrote:Yes - in that case you just drag a colour block down from the 'color library' and insert that in the video track and set it's length to your requirements.
Thank you Brian.
