Photo Size
railroadguy
motherboard: Acer Aspire TC-1770
processor: ntel 13th Gen Core i5-13400
ram: 32 Gb
Video Card: NVIDIA GeForce GTX 1050 Ti
Hard_Drive_Capacity: 1 Tb SSD
Monitor/Display Make & Model: Acer AL2251W
Corel programs: Corel Video 2023 Ult
Photo Size
Post by railroadguy »
When mixing HD 1080 video with digital photos it looks like I have to manually crop to 1920 x 1080 or at least that ratio to stop from having black bars on either side of the project? I am new to VS 4 and HD in general. Other then allowing VS 4 to "stretch" an image is there an easier then crop each image?
I am using a Canon 550D for both video and pictures.
Thanks,
Dan
Kingston
motherboard: Gateway [Acer] DX4860
processor: Intel Core i5 3rd gen. 3 GHz
ram: 8 GB
Video Card: Intel HD 2500
sound_card: Bluetooth
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Dell ST2210; Samsung SmartTV 3D 40"
Re: Photo Size
Post by Kingston »
Here's one way:
1. Select a photo clip on the timeline, then click the Attributes tab up over in the options panel.
2. Select the "Distort" option.
3. Right-click on the preview window and select "stretch to fit" from the pop-up menu, and then right-click again and select "keep aspect ratio."
4. Right-click on the photo clip on the timeline and select "Copy Attributes" from the pop-up menu.
5. Select all the other photos on the timeline, then right-click on one of them and select "Paste Attributes" from the pop-up menu.
Re: Photo Size
Post by Trevor Andrew »
Just to add…..
Make sure all images are landscape types, if you have a portrait image then it will be distorted by a lot.
When you select the distort option the preview screen shows a white rectangle, this indicates the Safe Area.
Some detail outside this box may not be seen on the TV due to Overscan, so the black borders will also be reduced?
Not normally a problem with a video clip but images we tend to crop quite tightly.
railroadguy
ram: 32 Gb
Re: Photo Size
Thanks. I knew there had to be an easier way :D
Thanks,
Dan
