Howie
Posts: 10 Joined: Fri Oct 07, 2011 11:36 pm
motherboard: Gigabyte GA-P55M-UD2
processor: QuadCore Intel Core i5
Video Card: GeForce GTS 250
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Standard PnP 16:10
Post
by Howie » Sat Oct 08, 2011 3:27 pm
Today I purchased the full version of PSP4, but stupidly I uninstalled the trial-version first. Now I am getting
Code: Select all
Corel PaintShop Pro X4
Your system has not been modified. To complete installation at another time, please run setup again.
OK
Is there a clean-up tool out there similar to PSP3?
df
Posts: 1224 Joined: Mon Feb 08, 2010 11:21 pm
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Post
by df » Sat Oct 08, 2011 9:39 pm
You should have left the trial version active and just used the activation code to unlock it (or whatever Corel calls it).
How did you uninstall the trial version? Have you checked the install/remove programs to see if it's still there? If so try to uninstall again.
What security programs do you have running? Firewall program? Antimalware?
Have you turned off UAC (User Account Control)?
Have you tried running the installer file as an Administrator? (right click, run as admin or properties> run as admin)
You may try creating a different account in Windows and installing in the new account. If that works you'll then be able to delete the new account after you verify you can use the software in the main account.
Regards, Dan
Howie
Post
by Howie » Sat Oct 08, 2011 10:23 pm
Hi, Dan - evrything You described has been tried, and I even created a admin-account, but I am still stuck with the same error-message.
Posts: 22481 Joined: Fri Dec 10, 2004 9:36 pm
Post
by Ken Berry » Sat Oct 08, 2011 10:37 pm
Although perhaps not precisely similar, you might want to look at this detailed response to another user having difficulty installing:
http://forum.corel.com/EN/viewtopic.php ... 82#p227582
Howie
Post
by Howie » Sat Oct 08, 2011 10:58 pm
Hi Ken - tried these suggestions too, but still stuck.
JStanley
Posts: 313 Joined: Wed Jul 27, 2011 12:41 am
Post
by JStanley » Sun Oct 09, 2011 4:34 am
deleted
JStanley on Fri Mar 16, 2012 8:52 pm, edited 1 time in total.
bkz
Posts: 4 Joined: Sun Oct 09, 2011 3:37 pm
motherboard: PEGATRON CORPORATION Eureka3 1.01
processor: 2.50 gigahertz Intel Core2 Quad
Video Card: ATI Radeon HD 4350
Hard_Drive_Capacity: 640GB
Monitor/Display Make & Model: NEC MultiSync 77F
Post
by bkz » Sun Oct 09, 2011 3:51 pm
I'm having the same problem but never installed the trial version. I've got Photo Pro X3 installed and am trying to install Pro X4 from a dvd (purchased the boxed version).
df
ram: 64gb
Post
by df » Sun Oct 09, 2011 6:30 pm
Again, what security programs do you have?
Regards, Dan
bkz
Post
by bkz » Sun Oct 09, 2011 8:20 pm
I've got Microsoft Security Essentials. I turned off real-time protection and turned off my firewall but got the same message.
bkz
Post
by bkz » Sun Oct 09, 2011 11:12 pm
OK, got it! Needed to turn off Microsoft Security Essentials real-time protection:
MSE / Settings / Real-time protection / Uncheck "Turn on real-time protection"
Then REBOOT
Then try the PSP X4 installation
The installation completed successfully.
Howie
Post
by Howie » Mon Oct 10, 2011 2:41 pm
My problem solved too - today I got the PSP4 clean-up tool from Corel Support.
Howie
Post
by Howie » Mon Oct 10, 2011 3:57 pm
Oops!!! I was a little too fast - I managed to install the program, but there is no launch-icon (exe) in the programs-group nor in the folder where the program is installed. I have installed on an admin-account with clean boot and antivirus/firewall turned off as suggested by Corel Support. What else can be done now?
Kathy_9
Posts: 2896 Joined: Tue Nov 30, 2010 12:44 am
Post
by Kathy_9 » Mon Oct 10, 2011 6:14 pm
Mine is located here C:\Program Files (x86)\Corel\Corel PaintShop Pro X4.
Howie
Post
by Howie » Mon Oct 10, 2011 6:41 pm
Kathy_9 wrote: Mine is located here C:\Program Files (x86)\Corel\Corel PaintShop Pro X4.
Tried that too, but with the same result.
I simply don't understand why it schould be so difficult installing PSP4 - I do not have similar problems with other programs.
teknisyan
Posts: 2421 Joined: Wed Oct 06, 2010 4:18 pm
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Post
by teknisyan » Mon Oct 10, 2011 11:35 pm
You may want to reply to the Corel Support that provided you the email, So that they can continue with the steps that they provided you.
