Has anyone had this before?
Failed to read DVD information.
Report ID: 0x80040901 (2305)
It's the response to Create DVD - Import video file from hard disk,
and appears for about 1 in every 5 video files, though there is never anything different or unusual about the 1 that produces it.
Another meaningless message
DripPan
I have the same thing. I record from to my tv dvd recorder, bring it to my computer, spiff it up really nice and neat.
It only happens about every 4 or 5 times but it's enough to tick me off. I've tried downloading it to hard drive. I'm still playing around with it and will let you know if I come up with a solution.
The big thing is is that I have to save my work alot in MF 4.0 because I don't know when it's going to shut down on me. I'm going to look around to find a solution for this but it would seem like their tech support should be all over it!
DripPan
DripPan
maddrummer3301
derebo
hi,
i get a similar error:
"failed to begin VIO playback instance in the import dvd preview module. report ID: 0x8004095a(2394)"
when trying to import a dvd-vr recorded in a panasonic dvd recorder. my computer dvd-reader-writer is NEC ND-2510A.
how ulead guys have a closer look at this issue...
greetings,
greetings,
maddrummer3301
Is that a dvd-rw or dvd-ram disk. Didn't think the NEC could read dvd-ram disks.
Recording onto dvd-ram from a panasonic unit gave same error.
After installing the latest update 4.03 from the ulead website I import from the dvd-ram disks no problem.
Have you downloaded and installed the 4.03 patch? Then rebooted?
MD
MD
derebo
hi maddrummer3301,
thanks for your reply. it's a dvd-rw disk (not a dvd-ram). so seemingly NEC can't read dvd-rw disks written in dvd-vr format. at least, directly. if i use isobuster i can open it and save the contents to the HD. i've already installed the 4.03 patch and it didn't work. but i have not rebooted the system so far (it's processing). as soon as i do it, i'll try it again and report here.
greetings,
greetings,
maddrummer3301
I'm assuming you know to finalize the dvd before trying to use it in other machines.
The NEC should read the dvd unless it's a +drive only but even then I believe it should still read the dvd as read-only because it's closed and finalized.
If using win2000 you maynot be able to view the contents.
XP should be no problem.
MD
MD
