Trevor Andrew, Please look at this.
PEGACON
- motherboard: Intel
- processor: Pentium4 3Ghz
- ram: 2GB
- Video Card: Geforce4 TI 4600
- sound_card: Realtek
- Hard_Drive_Capacity: 160GB
Hello. I'm a Korean and I live in South Korea.
I'm not speak english very well so, I ask to be excused.
Thank you for your help.
You are in part right.
I send my e-mail to you, include attached file.
Now, you check your e-mail please.
attached file name = file.zip
And look at this.
<A> Corel MotionStudio 3D 1280x720
<B> Ulead COOL 3D Studio 1280x720
All are the same quality option and the same codec.
Compare <A> and <B>..
The result.. <B> is better than <A>. a little bit.
So, I find out, The COREL much love The Rendering Speed than The Rendering Quality.
If you want to learn more about this, keep reading my POSTREPLY 001 - 014 below.
And look at this.
You do not have the required permissions to view the files attached to this post.
PEGACON
- ram: 2GB
Re: 001-003
001-003
PEGACON
- ram: 2GB
Re: 004-006
004-006
Re: Trevor Andrew, Please look at this.
I'm trying to figure this thread out - Your codec screenshots are Microsoft settings for the Microsoft codecs, these are not Corel codecs. The screen shots you have submitted show the settings in Windows Media.
Jan -- you might want to take a look at Pegacon's other posts here, and in particul this one which is related to this new thread: http://forum.corel.com/EN/viewtopic.php ... 33#p229633
Hi Pegacon
Wow
Sorry for the delay in replying, had you continued the original post i would have seen it immediately
Lots of work gone into providing the images.
I mentioned in an earlier post that I did not have Cool3d installed so cannot compare qualities.
Only working with the trial C3D and have 2 days left.
I notice on some of your images that you render the video file to 640px, as I said this is not going to produce the best quality.
For HD you need to use 1280 x 720 as a minimum frame size.
The images however don’t show the actual finished quality, if you can provide a sample maybe on youtube then we would be able to compare the differences you are experiencing.
I have rendered a C3D project to Avi Mpeg4, there may be a better option.
I will try other video options to see if the quality improves.
View the samples on you tube in full quality.
Wow
I just created projects that were identical in C3D PS, and MS3D. Rendered both to DV type-1 (avi) files. I fail to see a difference in the quality. I could upload them to YouTube, however that in itself is not going to be an accurate depiction. YouTube will convert them to FLV, which does affect quality.
Your first video example states you rendered it to "avi mpeg-4". Which is it? Did you wrap a mpeg-4 in a avi container? You should have either an *.avi or *.mp4. Then like I stated above, when you upload to a service like YouTube you're going to take a hit on quality, how much depends on a lot things.
Hi Ron
For the file conversions of all three I chose Avi using the Mpeg4 compression option. (Microsoft MPEG-4 Video Coded V1)
I found this gave me the options to set the different file sizes.
Custom Mpeg4 files does not give the frame size options
The only MPEG-4 I can find on my system using the AVI wrapper is DivX or Xvid. MPEG-4 does not use the avi wrapper otherwise. For the HD video files, I have to use the MPEG-4, or m2t (mpeg).
Hi Ron
I Share Create Video File-Custom
Choose Avi
Options
Avi Tab- compression Microsoft MPEG-4 Video Codec
The template properties show as :-
Microsoft AVI files
24 bits, 720 x 576, 25 fps
Lower Field First
Microsoft MPEG-4 Video Codec V1
PCM, 48.000 kHz, 16 Bit, Stereo
Choose Avi
Options
Microsoft AVI files
Lower Field First
Ron -- your image is from Video Studio, not MS3D... However, I am unable to check right now as my MS3D seems to have disappeared apart from non.exe type files. I guess the trial period is over! But if so, it would be a strange way to stop the program, without any screens telling me I must now purchase it...
