HI
in The next clip in 1:58 there is effect of the two screens next to each other when one gets big and one stayed the same. I know this is a picture in picture effect I tried to di it but could not reach this result, is there anyone who can explain how to do it, I'd appreciate it very much
the exemple
http://www.youtube.com/watch?v=T_M5-qth ... e=youtu.be
How do I do this effect?
KOBRA76
- motherboard: Gigabyte
- processor: 3.07 gigahertz Intel Pentium Dual-Core
- ram: 2 GB DDR3
- sound_card: VIA High Definition Audio
- Hard_Drive_Capacity: 500GB
Canon 550D,18-55 & 50mm Lenses
My You Tube Channel
http://www.youtube.com/user/HDMAN2012?feature=mhee
My You Tube Channel
Re: How do I do this effect?
Have you looked at this tutorial on how to use the PnP filter: http://www.vimeo.com/8978357 It was made for X3 but will work also for X4 since it is the same filter. The important thing is that you have to first apply a mask.
KOBRA76
- ram: 2 GB DDR3
I've seen This guide before, I know how to use this effect, I want to do what I have published and I do not know if it can be done in COREL
My You Tube Channel
My You Tube Channel
I disagree. That effect is quite possible using the New Blue FX, PiP. I was able to recreate that effect quickly. Spending more time with it and you'll learn just how powerful it is. This is a short example that took me less than 5 minutes to create. It's not perfect, but I wasn't aiming for perfection to just demonstrate that the effect you're referring to can be done quite easily in VS.
To do this you need to start on the first keyframe of the PiP, with Reset to none. Move to a position just before you want the full screen size to start resizing, and copy that first keyframe or, just select reset to none again. Next move to where you want the split-screen/side-by-side, now resize the clip, making adjustments to the size and position.
Don't rely just on the templates provided with the effect. Those are just examples to use, to get you started. Did you know that you can save your customized settings?
KOBRA76
- ram: 2 GB DDR3
Thank you, you were right that it can be done in Corel.here is my result to this effect
http://www.youtube.com/watch?v=qtXR0pcZ_Jg
My You Tube Channel
My You Tube Channel
KOBRA76
- ram: 2 GB DDR3
no i dont no,how can i save my customized settings?
My You Tube Channel
My You Tube Channel
First understand that a preset does not contain all the keyframes in the timeline. It is the settings for one keyframe. So to save an entire effect you must save each keyframe separately.
Across the top you will see 3 buttons one being a P, which stands for Presets. Click on that button to open a menu, which will show all the presets for the PiP effect. These are the same as all the thumbnails. Notice at the bottom to options, Open Preset and Save Preset as. To save your preset settings for a keyframe, select the Save Preset as, a dialog window will open provide a name and location on your computer to save it.
Once this is done, you can simply open your preset to add it. I find this makes it much easier to add those keyframes when you want an effect to remain static for a period of time, instead of even copy/pasting. Plus it will be there to add to additional clips.
KOBRA76
- ram: 2 GB DDR3
The best thing is to export the effect as atemplate,and open it from the instant project.
My You Tube Channel
My You Tube Channel
KOBRA76
- ram: 2 GB DDR3
I do not get along with the key frame in pip effect, how do I make that the first part of the picture will be in Steele mode and the other part will be based on what I will make
thank you
thank you
My You Tube Channel
My You Tube Channel
