Corel X3 patch 5 and plugins help needed
Filly
motherboard: ACPI X64BITS- PC
processor: AMD Phenom tm 11 X6 1090T Processor 3.20GHZ
Hard_Drive_Capacity: 1TB 350GB
Monitor/Display Make & Model: LG 23 INCH W253
Post by Filly »
I have installed the latest patch..must admit it has made a big difference..
It doesn't crash on adjust variations which it was doing..they work, display is black no image..
But..I still can't get FU to work on a transperent layer works fine on a merged on..
Ulead plugins still not working help to get these working would be appreciated..
Thanks Cheers
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Re: Corel X3 patch 5 and plugins help needed
Post by teknisyan »
I'm sorry to hear about this, Filly. Can you tell me what is the name of the plugin that you are referring?
Can you tell me if the plugin was originally working with PSP X3 when you first installed the program? I have created a case for your issue (via Private Message), so in case you will call Corel Customer Support about this issue, you can use the case number that I can created for you.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
Filly
Post by Filly »
Abiel Filters Ulimited didn't work before the patch still doesn't.
It will work on a merged image but not on a layer..
I believe Corel know this and are working to find a solution..
Ulead are another..Cheers
I
JStanley
Post by JStanley »
deleted
Filly
Post by Filly »
FU is still the same the patch hasn't fixed it..
There is an import fix..have used that it made no difference..
FU works perfectly in X2..so it couldn't be the filter
it has to be X3 I am not alone with this problem..
Was using X3 tonight and the old memory problem popped up..
not enough memory!!!!!!!!
Cheers
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
There have been a number of threads recently about FU plugins not working and I've lost track of who has done what to try and correct it, so forgive me if you have already tried this. http://www.filtermeister.com/fmpatcher/index.htm
Filly
Post by Filly »
Thanks Yes have used FMPatcher that only works on Filtermeister plugins..
It is a general problem with FU and X3 if you take it back to patch 2 it works..
then other like some Alien ones don't so you can't win..Cheers
