Hi All
New to PSP X3 -took a number of pixs of the kids on the trampoline which has an enclosed netting and of course i was outside - the neeting is bery fine - is there a way to edit it out
thanks in advance
david
removing netting
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: removing netting
Slowly and carefully....not much else I can say there.
You can use the clone brush, very small clone brush, to select areas without netting and draw over the netting...or you can use a paint-brush with the necessary color and hope the changes aren't too noticeable (which they probably will be).
The biggest problem is that with a fine-netting you still get more of the net overlaying over the subjects so it's very difficult to just get rid of it. I suggest you just leave it and enjoy.
Joelle
- motherboard: Asus Prime B350M-A
- processor: AMD Ryzen 5 1500 Quad-Core
- ram: 16 GB RAM
- Video Card: NVidia GeForce GTX 1050
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Samsung
- Corel programs: PaintShop Pro X9
Have you tried the Scratch Remover tool?David P wrote:Hi All
thanks in advance
david
Zoom into the image and spend a few days removing netting!
Best way to avoid netting is to get very close to it then it will be out of focus when you take the photograph.
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
- flagpole
- motherboard: Gigabyte B450 AORUS ELITE DDR4 USB 3.1 RGB
- processor: Ryzen 2600
- Video Card: RTX 2060
- sound_card: on board
- Hard_Drive_Capacity: 6.5TB
- Monitor/Display Make & Model: Iiyama 27"
are there any fourier transform based filters for PSP? mathematically it would be a perfect solution. might not look good though.
Thanks for the advice
df
- ram: 64gb
- Hard_Drive_Capacity: 1 Tb
http://vicanek.de/plugins/wireworm.htm
This plugin works with PSP, at the bottom of the page there are also links to similar stuff.
Regards, Dan
