I have just tried to reinstall my copy of X2 on my new PC, it was fine at first but the trial countdown started to appear when loading.
The trial countdown has now reached 0 days and I can no longer load X2.
I have done a complete uninstall including scrubbing the registry, re-installed, but get the same result.
I even downloaded a fresh copy of the file from Corel along with the serial number and it still doesn't work.
What is even more frustrating is that I'm not even using a trial version!
If anyone has any ideas, all welcome.
Mike
PSPx2 reinstall problem
Wilco
- motherboard: Alienware 07JNH0 A02
- processor: 4.20 gigahertz Intel Core i7-3960X
- ram: 16Gb
- Video Card: AMD Radeon HD 7900 Series
- Hard_Drive_Capacity: 4418.48 Gb
- Monitor/Display Make & Model: 3xDELL 2007WFP
Windows 7 Home Premium
3.30 gigahertz Intel Core i7-3960X overclocked to 4.2GHtz
16Gb Ram
4.5Tb total HD space
AMD Radeon HD 7900
3xE207WFP displays
16Gb Ram
AMD Radeon HD 7900
3xE207WFP displays
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Re: PSPx2 reinstall problem
If you are installing PSP X2 on Windows 7, then that could be the problem. since PSP x2 is not fully compatible with Windows 7. You can visit http://corel.force.com/index/articles/e ... patibility, to know which version of the Corel Software is compatible with Windows 7.
There is a workaround for you to make old program works on Windows 7, however we cannot assure you this is a 100% fool proof. You can use the Windows 7 Program Compatibility and the Windows XP Mode with Virtual PC, which are both from Microsoft.
You can follow the steps for Windows 7 Program Compatibility from this link: http://windows.microsoft.com/en-US/wind ... of-Windows
You can download and install the Windows XP Mode with Virtual PC from this link: http://www.microsoft.com/windows/virtua ... nload.aspx.
You also want to consider upgrading your Corel software, since PSP X4 is full compatible with Windows 7, you can download the 30 day full working trial at http://www.corel.com/trials.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
Filly
- motherboard: ACPI X64BITS- PC
- processor: AMD Phenom tm 11 X6 1090T Processor 3.20GHZ
- Hard_Drive_Capacity: 1TB 350GB
- Monitor/Display Make & Model: LG 23 INCH W253
You shouldn't have any problem with it in W7 even though Corel say it isn't compatible..
Myself and a lot of my psp friends disagree and have told Corel so..
I had the same problem after I bought X2 a couple of months agao..
mine wasn't a trial version..but it kept saying only so many days left..
After about 21 days up came a notice to activate it..
Corel gave the activation number plus a new serial number..
Get on to Corel to give you a new installation with new serials and activation code..
When they do completely remove your copy also the psp files in your documents
remove all trace of it..
Did you do that when you recived the new one..
perhaps that is the problem
Cheers
Cheers
Wilco
- ram: 16Gb
Both of these ideas are not going to get me anywhere! The option to download XP Mode is only open to these who possess Windows 7 Professional or Ultimate!
I have tried uninstalling every bit of Corel software on my Pc and gone through my registry with a fine tooth comb and deleted every reference to Corel, re-installed PSP X2 and still get the error.
I have had X2 running fine under Win7 for over a year before this problem reared its ugly head so why the problem now?
I think Filly has the right idea and obtain a new serial key, I don't see why I should go to the expense of upgrading to a newer version when the old one was working fine!
16Gb Ram
AMD Radeon HD 7900
3xE207WFP displays
16Gb Ram
AMD Radeon HD 7900
3xE207WFP displays
Do you know the serial number, if not login to your corel account and view your registered products.
Assuming you have registered when you purchased?
When you installed the X2 did you not get the option to insert your serial number, if not during installation then while using the trial you can normally click “Already Purchased” which as far as I know takes you to an activation screen.
I did a search of the knowledge base and found this info, may be useful?
000004867 - Completely uninstalling and reinstalling Paint Shop Pro Photo
000004440 - Activation of Paint Shop Pro Photo X2 Ultimate - Written Instructions
Wilco
- ram: 16Gb
This is all very odd, I was just about to uninstall it all again but thought to try running the program one more time. This time the Activate Now button came up (for the first time) so I went through the activation process and hey presto, it is all working now.
It must have been the threat, to my Pc, of going over to Photoshop that did it
Anyway, all's well that ends well, thanks for the advice,
Mike
Mike
16Gb Ram
AMD Radeon HD 7900
3xE207WFP displays
16Gb Ram
AMD Radeon HD 7900
3xE207WFP displays
Filly
Did you keep a copy of the activation code you may need it later pleased you sorted it out..
It is a good version I like X2..Cheers
Wilco
- ram: 16Gb
Certainly did, locked away in a fireproof safe with an armed guard willing to shoot anyone who approaches
Cheers
Cheers
16Gb Ram
AMD Radeon HD 7900
3xE207WFP displays
16Gb Ram
AMD Radeon HD 7900
3xE207WFP displays
