enlarge image PSPro X
Kathy_9
Hard_Drive_Capacity: 2TB
Re: enlarge image PSPro X
Post by Kathy_9 »
Holy smokes!! When you attempt to re-size the image, do the same pixel dimensions show up in the re-size dialog box? If so, what happens if you attempt to downsize it - any issues?
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
In PSPro I go file -import-twain acqiure-in the Canon Scan Gear CS Box, main tab- the output resolution for the scan is
set to 300 dpi.
Now when I try to enter text on the image(which I have done before on the same image but saved under a different name with no problem) I get this showing
"Unhanced exeption code 102" and, in another box " paints 1.exe application error box" -
Instruction at 0x026b0313 referenced memory at 0x000000078memory could not be read-click OK to terminate the programme.
What is going on here?
The resize box has the same pixel dimensions and resolution for the original dimensions.Pixel dimension is 181%x181% W21187 H32767, if I try to reduce ,the not enough memory box shows.
Tadjio
motherboard: Gigabyte
processor: Core i7 2.8GHz 860
Video Card: ATI HD5570
sound_card: Sound
Hard_Drive_Capacity: 2.5TB
Post by Tadjio »
Kenneth Veal wrote:In PSPro I go file -import-twain acqiure-in the Canon Scan Gear CS Box, main tab- the output resolution for the scan is set to 300 dpi.
Can you see the Resolution under PSP Image Information (EXIF Information) - shortcut Shift+I?
It is described as X resolution (and Y) e.g. 300.0 dpi.
Also, can you save the image as a JPG and then use Windows Explorer File Properties to view the Resolution?
It is described as Horizontal resolution (and Vertical).
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
Ken Veal
ram: 32 GB
Post by Ken Veal »
on opening up the image again, the overview memory used now shows 603.646 MB
Exif info just shows all section boxes checked,nothing shows under value.
Properties only tells me it is 243 MB on disc and size
Tadjio
sound_card: Sound
Post by Tadjio »
Kenneth Veal wrote:on opening up the image again, the overview memory used now shows 603.646 MB
Are you saving as a JPG?
'cos if so it sounds big to me!
Tadjio
Ken Veal
ram: 32 GB
Post by Ken Veal »
Yes, saving as jpeg.Just realised why there is no exif info, although the latest state of the art technology was probably used,
it may have something to do with the fact that the picture was taken in 1942!
Tadjio
sound_card: Sound
Post by Tadjio »
Kenneth Veal wrote:Yes, saving as jpeg.Just realised why there is no exif info, although the latest state of the art technology was probably used, it may have something to do with the fact that the picture was taken in 1942!
Assuming your war-time shot is worth salvaging, I would still pursue the dpi or pixels per inch.
Windows Explorer File Properties Details Tab should show the Horizontal (and Vertical) resolution.
Can you set CanoScan to use a smaller resolution?
Tadjio
Ken Veal
ram: 32 GB
Post by Ken Veal »
The image was taken before my time and is of a friends grandfather in his uniform, it is in good condition but I want to enlarge it to put in a DVD made with V. Studio.I tried again, scanned it , the scan gear reported its dimensions correctly
(3.62 W, 5 inches high) 1036 W x 1804 pixels H.I altered the % to 200 and the pixels were then 2072x3008.Clicked OK,
this time no messages etc but nothing happened.So now I am back to square one.
Ken Veal
ram: 32 GB
Post by Ken Veal »
Properties only tell me it is 431 KB size on disc
Kathy_9
Post by Kathy_9 »
Do you have any other image editing software on your system? Maybe one of the free ones like Paint.NET? Or you could download http://download.cnet.com/Image-Resizer- ... 05400.html It's a free ap and it works via the right-click menu. Just right-click on the unopened file and select the custom size you want.
I'm at a loss for why PSP X won't re-size your image but if you can re-size it via another software program, you can always take it back into PSP to complete your edits.
Ken Veal
ram: 32 GB
Post by Ken Veal »
I do have Photo Impact XL which I have not used for years.Before I consider the link that Kathy kindly provided, can I be advised
on a click by click workflow for PSPro X to resize, It could be that I am not doing everything I should be
LindaSue
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Post by LindaSue »
Kenneth Veal wrote:I do have Photo Impact XL which I have not used for years.Before I consider the link that Kathy kindly provided, can I be advised
Make sure that you've got "Resize all layers" and "Resample" both checked.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
Kathy_9
Post by Kathy_9 »
Here's a tutorial with screen shots. http://www.digital.mississippi-photo-ga ... /resizing/
