enlarge image PSPro X
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
I go-image-resize-resample-unncheck resize all layers-set new value via % (tried 400%)-lock aspect ratio in a jpeg image.but not much happens, I want to try and double the size, where am I going wrong?
flagpole
motherboard: Gigabyte B450 AORUS ELITE DDR4 USB 3.1 RGB
processor: Ryzen 2600
Video Card: RTX 2060
sound_card: on board
Hard_Drive_Capacity: 6.5TB
Monitor/Display Make & Model: Iiyama 27"
Re: enlarge image PSPro X
Post by flagpole »
could it be that the image is resizing, but then it's zooming out?
teknisyan
processor: Intel Corel i5
ram: 4 GB
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500 GB
Post by teknisyan »
You are doing the correct steps and just like what flagpole mention, you may want to check if you are currently zoomed-out.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
Ken Veal
ram: 32 GB
Post by Ken Veal »
Think I need some more detailed guidance here, I have adjusted parameters, only to get part of image enlarged and viewable, have zoomed in and out with no joy.Even got a message saying I did not have enough memory to complete the operation.Can any one give me a step by step work flow please.For example, how to double the size of the image.
LindaSue
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Post by LindaSue »
Kenneth Veal wrote:Think I need some more detailed guidance here, I have adjusted parameters, only to get part of image enlarged and viewable, have zoomed in and out with no joy.
That's because you unchecked "Resize all layers". If you want to resize the whole image, including all layers, you must check that box.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
Ken Veal
ram: 32 GB
Post by Ken Veal »
I have not done any work on the image, so if I understand correctly, there are no layers.
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
Just curious - how large is the image that you are attempting to increase by 400%?
Ken Veal
ram: 32 GB
Post by Ken Veal »
The original image is 3x5inches, I did not really want to increase it by 400%, I used that figure in desparatrion when there was no response from what I was doing as described above.I just wanted to double its size but nothing worked.
Kathy_9
Post by Kathy_9 »
Since you are talking in terms of inches, I'm guessing you are trying to alter the print size. If so, have you unchecked the box that says "maintain original print size"?
Ken Veal
ram: 32 GB
Post by Ken Veal »
The "maintain original print size " box has never been shown as checked.I have tried increasing the pixel size and %, nothing happens apart from a message saying that I do not have enough memory and close other applications.Doing so only gets a repeat message.If it makes any difference, this image is a scanned print imported via PSPro X.Has the drop down list under "smart size" got any bearing on this problem ?(bicubic,bilinear,pixel resize and weighed average)
Kathy_9
Post by Kathy_9 »
I have successfully re-sized images that were scanned/imported via PSP with no problem, so I don't think that is what's causing your dilemma. As far as the drop down box goes mine defaulted to bicubic and I've never messed with it.
Just for the heck of it, have you tried shutting down PSP and rebooting your computer to free up memory?
Ken Veal
ram: 32 GB
Post by Ken Veal »
As it happens I have done that, with 4 gig of ram I cant see how this can be a memory problem,but thanks for the replies
Tadjio
processor: Core i7 2.8GHz 860
Video Card: ATI HD5570
sound_card: Sound
Hard_Drive_Capacity: 2.5TB
Post by Tadjio »
What is the Resolution (dpi) of your scanned image?
Either check in Windows Explorer File Properties or
PSP Image Information (JPEG Information) via Shift+I in Edit Mode.
Also, what does the Overview Palette in Edit Mode tell you is the Memory used?
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
Ken Veal
ram: 32 GB
Post by Ken Veal »
Output resolution (dpi) of scanned image is 300
Memory used not listed under overview info (clicked on info in Overview pallet)
Right clicked on image - in current info box-
1 Layer
11680 x 18061 pixels
128.352 x 198.505 inches (dont understand this, the original image is 3x5inches-or is this some other measurement?)
Pixels per inch 91000
RGB 8 Bits per channel
Memory used on disc 24910 K in Ram 618133 K
Tadjio
sound_card: Sound
Post by Tadjio »
Kenneth Veal wrote:Output resolution (dpi) of scanned image is 300
"Pixels per inch 91000" looks suspicious.
Is your scanner set to a very high scan resolution?
Where does the "Output resolution (dpi) of scanned image is 300" come from?
I suspect your image is very large in PSP (618Mb)
Typically my photos are about 55Mb.
Tadjio
