MOV file to MPG or to VS for edit or to make DVD
erdna
motherboard: Gigsbyte H81M
processor: I7 4770
ram: 16GB DDR3
Video Card: Intel HD4600
sound_card: Intel display audio
Hard_Drive_Capacity: 1TB 7200rp
Monitor/Display Make & Model: Panasonic TX32cx600e
Re: MOV file to MPG or to VS for edit or to make DVD
Post by erdna »
I think that VSX2 can handle (and convert for DVD) this high bitrate mpeg2 files. I use VSX2 nowadays to create1080p50 mpeg2 video's from my 1080p50 camcorder. The original fullhd 50p files are at 28mb/s avc/h264 ('avchd"). After editing I render as 1080p50 fullhd mpeg2 files with 50mb/s VBR.
Post by Trevor Andrew »
Hi erdna
Unfortunately the video is using non standard properties which are neither HD or SD DVD.
So Video Studio cannot properly read or identify the actual video.
720 x 480 x 20000 is a strange combination.
Ilene
motherboard: Thimphu intel Z 170
processor: i7-6700K quad core
ram: 16GB DDR4
Video Card: 6GB NVidia GeForce GTX 980Ti
sound_card: envy audio AV - band and olfson 5.1 channel
Hard_Drive_Capacity: 550SSD+
Monitor/Display Make & Model: Dell Ultra Sharp 25" 2560x1440
Corel programs: VSX8 32 And VSX9 64 and VSX10 32
Post by Ilene »
ok... will suggest that. Thanks so much for the advice. I will try it out and get back to you!
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
I'll go back to my reply in that FCP can produce Mac only files or can be told to produce a file that can be used by Windows machines.
Converting the Mac only file to one that windows can use is one option, but is a conversion too many. Asking the chap who has FCP and the Mac to output a windows compatible file will be the best in terms of quality.
Sorry for delay in replying, but I've been away for the weekend.
Ken,
Think of MOV as you do AVI.
It is exactly the same, but the Apple version, so our windows dv.avi is the same as Apples dv.mov, but as you know never the twain will meet in Apple v MS.
I'm currently having 126 clips captured by an Italian Mac from an HDv source and sent to me of my Brothers wedding for me to produce him a bluray wedding video, but of course I can't use any of the clips, so my friend who has a Mac is using it to make this conversion for me. We are having to make the conversion as sending back to Italy in the hope they have the original tapes and will send them over and then that they get here is maybe expecting too much.
Ilene -- thanks for the new mpeg-2 with the bitrate set at 8000 kbps and otherwise DVD-ready. However, as you already know, VS shows it also has no audio, despite Gspot saying its audio is mpeg-1 layer 2 and that the codec is installed. And like the earlier file, it plays in media players like WMP with audio, but not in VS... GSpot also shows it is (correctly) program stream mpeg-2 and needs no further adjustment for it to be fully DVD-compatible. So I am stumped.
I also had a 'duh' moment when I realised that of course, while Corel might not make mpeg audio available any longer for DVDs, it certainly contains the codec since mpeg audio is *the* audio used by HDV camcorders (such as my Canon HV20) which I use all the time successfully, with audio, in X2, X3 and now X4! :oops: But I simply have no idea why your video will not play the audio in your or my Video Studio...
Ilene
ram: 16GB DDR4
Post by Ilene »
thanks for trying... I think I'm back to using MOV file directly, or ripping from his DVD, using "capture from imported media" and going with the scarcely noticeable degradation in quality.
ugh... so frustrating always to deal w MAC vs PC.
btw - windows dvd maker, reads the file just fine... there is just very little customization available for the menu screen!
Curiously enough, I also get no sound when I insert the latest file in Windows DVD Maker and try to preview it. Yet you get sound in preview?
Though it is a bit counter-intuitive, can your Final Cut friend output in Transport Stream mpeg-2?
I also just converted your video to a .vob file using a third party conversion program, and then renamed .vob to .mpg. And this time the audio played happily in X4. (However, the program I used messed up the aspect ratio of the video). But the experiment gave me another idea. Gspot tells me the original audio is at 48,000 HZ and 384 kbps. The new file I created still has mpeg layer 2 audio, but at 44,000 Hz and 128 kbps. So I am wondering if your friend can adjust the audio output settings to the latter i.e. 44000 HZ and 128 kbps and leave it at 16 bit stereo. I imagine 196 kbps would also work since it is normally in the range played by VS and would give better audio quality.
Hi Ilene Ken
Thanks for the second sample, but as Ken has described, very similar to the first but with a lower bit rate.
Now this may be not important but……I have played the video using VLC Player, It does play but with a few problems, interestingly when viewing the files properties it shows the Streams differently.
There are two Streams 0 and Stream 1
Ilene’s video shows Stream 0 as using Audio
With Stream 1 assigned to video.
I created my own video sample using X4
Now this video shows the Stream 0 as Video and obviously Stream 1 as Audio
Now this is getting a little complicated for my little brain, maybe there is nothing in this, just seems odd to me?
I am again able to use Super to convert the video and play in VS
Ilene what problems are you having using the original Mov files? It it a Mac issue?
Thge streams issue (from GSpot) was the reason I asked if her FCP friend could make a transport stream instead of the PS file he was making -- in case that had something to do with it.
But the more I think about it, the more I suspect that the audio properties -- and particularly the Hz value -- might be the problem...
Ilene
ram: 16GB DDR4
Post by Ilene »
Hooray--- something that was said in the last exchange sparked something for my buddy and he was able to create a file for me that worked... he chose an option for mpg2 that was called "transport stream" -- he thought it was an intermediary codec and not a final codec? not really sure what that means but the file tested out well and rendered perfectly.
I have a screen shot of the properties, but I can't seem to figure out how to post to this site... I will email it to you, Ken and Trevor and then you can post for me?
hope it will be helpful to someone in the future....
Many thanks for all the support and guidance.
Ilene
Glad that one worked! Though I would also like to know if the changing of the audio parameters also might have worked...
For the record, have a look at this image which may help you post an image here in future:
Ilene
ram: 16GB DDR4
Post by Ilene »
ok... perfect. Never looked down there... I was only looking at options on the top of this screen.
thanks
Hi Ilene
Very glad to hear you have finally created a video file that works. Thanks to Ken for his TS suggestion
One thing that puzzles me regarding your e-mail comments.
You said “THe clean mpg that i referred to is the DVD which HE burned for me and I ripped... not his MOV as the source”. .
Not to worry, at least you have a workable video file
Ilene
ram: 16GB DDR4
Post by Ilene »
Ripping from his DVD to get an mpg file that plyed audio and video in VS was a work around solution. Sorry for the confusion. The MOV file he gave me directly didnt work so well.... I had quality issues despite it's size and format. For some reason that MOV file played perfect on a MAC but not on the PC so I wasn't able to use it. Still going to try to sort that out as well.
Thanks for the help!
Ilene wrote:Ripping from his DVD to get an mpg file that plyed audio and video in VS was a work around solution. Sorry for the confusion. The MOV file he gave me directly didnt work so well.... I had quality issues despite it's size and format. For some reason that MOV file played perfect on a MAC but not on the PC so I wasn't able to use it. Still going to try to sort that out as well.
MOV files created on Mac machines will never, ever directly work on a PC. The reason is that the machines are totally different platforms. They are competitors in the marketplace. With some of the high-end Mac programs, such as FCP, you are able to produce video files for PCs, but must be specifically done. MPEG happens to be one format that is recognized as a cross-platform format.
