WIA scanner
chaucersmom
WIA scanner
Post by chaucersmom »
I just purchased a new scanner -- CanoScan LIDE 110. It is a WIA scanner. I can scan successfully into PSPro X3 from the scanner by using the "import from scanner". But I want to use the scanner icon in the toolbar line to start the scan. It appears that shortcut button is looking only for a twain scanner because it says "No scanner found." How do I get the shortcut scanner icon to look for my WIA scanner?
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: WIA scanner
Post by LeviFiction »
Yes, the scanner icon is for TWAIN.
The icon for "From scanner or Camera" is a camera icon. So you can replace the icon on the standard toolbar but it won't look like a scanner.
If you want to do that go to your View menu and select "Customize" from the bottom. In the commands tab under "File" you should see an option to import from scanner or camera. Drag that onto the toolbar next to the scanner and then you can use it.
chaucersmom
Re: WIA scanner
Thanks LeviFiction, that worked! The icon looks like a camera.
Tadjio
motherboard: Gigabyte
processor: Core i7 2.8GHz 860
Video Card: ATI HD5570
sound_card: Sound
Hard_Drive_Capacity: 2.5TB
Re: WIA scanner
Post by Tadjio »
Firstly you have to set the Source within File > Import > TWAIN Source...
TWAIN or WIA Source
TWAIN or WIA Source
Then you can either Click on the Scan... Icon in the Menu
or you can use File > Import > TWAIN Acquire...
It's good to find I can use WIA Acquire from my iPhone :D
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
