X4 Organizer "Exclude" does not work
DENedbalek
motherboard: ASUSTeK Computer INC. Benicia 1.01
processor: 2.67 gigahertz Intel Core2 Quad Q6700
ram: 4GB
Video Card: NVIDIA GeForce 8600 GT
sound_card: Unknown Soundblaster compatible
Hard_Drive_Capacity: 2x 500GB
Monitor/Display Make & Model: LG Flatron W1952TQ
Post by DENedbalek »
Under preferences, if you select exclude a file type ("File Format Exclusions"), it has no effect on the files located and shown by Organizer. I am trying to exclude Adobe .pdf files and cannot get it to do so. Any ideas? or is this a bug?
Dwayne
Re: X4 Organizer "Exclude" does not work
It appears that it may be a bug. There's still things that Corel is working on. Using your example of *.PDF, I have a separate folder where I keep all my PDF documents. I just don't select that folder in the organizer.
None the less I think that you should report your findings to Corel.
DENedbalek
ram: 4GB
I posted my issues here first to check that I was not missing something easy. Since I received no fixes here, I've reported all of my "findings" (glitches, preferences, etc.) to Corel with limited acknowledgement so far. With a new release out there I'm guessing they are a bit busy.
Dwayne
DENedbalek
ram: 4GB
UPDATE: Corel has confirmed that they can duplicate the problem and will address it in a future update / fix.
Simone Corel UK
Alludo
Post by Simone Corel UK »
@DENedbalek
There is a known problem that XP users are not asked if they want to associate file extensions with PSPX4 and file extensions are automatically associated with X4. This leads to the problem that if you remove PSPX4 under XP, you have to associate each file type on your own in Windows.
Windows 7 and Vista is quite different. I have Vista at home and there is no file format/extension associated with PSPX4. If I go to Manage mode -> Browse for more folders and I choose Desktop (e.g.), then I get all jpgs and pdfs on my desktop shown.
The File format exclusion in Preferences only means "should I open a JPG with PSPX4?" (e.g.)
Could you please describe what you are trying to do and what the target is in your case?
DENedbalek
ram: 4GB
Under preferences->Manage there are options to exclude file types and folders from Manager. It does not work. If I specify to exclude .pdf's it does not exclude .pdf's.
Simone Corel UK
Alludo
What do you understand under exclude?
I have disabled all file associations in Preferences - Manage
When I use the Manage organiser, I still get my JPGs and PDFs shown, but both types are opened by Adobe's Acrobat Reader resp. Windows Picture viewer as default programs.
If exclude means in your opinion that the organizer doesn't have to show them, then it doesn't work like this. Otherwise we wouldn't get to see any image like our JPGs in PSP.
Tadjio
motherboard: Gigabyte
processor: Core i7 2.8GHz 860
Video Card: ATI HD5570
sound_card: Sound
Hard_Drive_Capacity: 2.5TB
Post by Tadjio »
This is what PSP X4 Help says:
"Exclude specific file formats from appearing in the Manage workspace"
This does not happen :shock:
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
Simone Corel UK
Alludo
Sorry, of course, I never noticed the Help description for it. I associated this setting with "Windows -> Open with".
We have to extend the problem to all file types because, it doesn't work at all. I just tested it in X2 and if I exclude JPG in X2, then they are not shown, but X4 shows them nevertheless.
I will look into the escalation process.
I do apologise for my "thick-wittedness"; I have never used the organizer as user of PSP.
Tadjio
sound_card: Sound
Post by Tadjio »
That's OK, Simone :?
The fact that this does not work is precisely why I don't bother with the Organizer - too many faults.
I think you should add to your escalation what I said elsewhere about "Uncataloged Folders":
Tadjio wrote:"Uncataloged Folders" or "Excluded Folders" as it used to be called are described in the Help System as:
"Specify folders to exclude from cataloging"
If you click on such a folder in Manage Mode, no Images appear
BUT
if you click on it again, all the contents is neatly cataloged for you :shock:
Tadjio
Simone Corel UK
Alludo
I can't confirm last one or I go another way:
I add a certain folder on my desktop to the "Uncataloged Folders".
I go in Manage to Browse for more Folders and choose the one.
That particular folder is marked as not show-able. I click on it, still nothing happens.
I close PSPX4 and re-open it. Still the same, I can't get to show.
I have to remove this folder from the "Uncataloged Folders" list, and then it shows the content.
Tadjio
sound_card: Sound
Post by Tadjio »
Simone Corel UK wrote:I go in Manage to Browse for more Folders and choose the one.
Click on any other folder and then go back and click on the "Uncataloged" one again.
Tadjio
Simone Corel UK
Alludo
Sorry, it's still not clickable. No image is shown.
Tadjio
sound_card: Sound
Post by Tadjio »
I'm running out of "Uncataloged Folders" with JPEGs in them to view so I can't easily repeat what I did before :roll:
Can you report it anyway with the other issue please, Simone?
Tadjio
Simone Corel UK
Alludo
Yes, the other issue is no problem, easy to reproduce, but I can't escalate something that I can't reproduce.
