PSP X4 three bugs
danielcg401
motherboard: ASUS Maximus III Formula
processor: Intel Core i7 860
Video Card: GeForce 9800 GX2
sound_card: Xi-Fi
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Dell U2410
PSP X4 three bugs
Post by danielcg401 »
1. Shadow/MidTone/Highlight adjustment dialog, if I select absolute adjustment method then change any setting least twice then preview result will be incorrect. Relative adjustment method work fine.
2. In Hue/Saturation/Brightness, when "Colorize" checkbox is enabled and I set Hue to any between 180 degrees and 360 degrees by using slider separate from the slider below the number, the background in entry box will turn light red indicate there are programming error with slider beneath the number. I can still use 180 degrees to 360 degrees as Hue without problem, though.
3. Corel PSP X4 always crash when I try to access "Color Working Space" function.
df
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Re: PSP X4 three bugs
Post by df »
3. when I try to go to Color Working Space, the only option is sRGB. I thought that this editor at least worked with Adobe RGB. Also when I import a file from Canon's DPP X4 warns me that its converting from Canon's sRGB version. It doesn't crash the program though.
Regards, Dan
el48tel
motherboard: Dell Inc. 0GDG8Y A00
processor: 3.00 gigahertz Intel Core i5-2320
ram: 8Gb
Video Card: NVIDIA GeForce GT 530
Hard_Drive_Capacity: 2Tb
Monitor/Display Make & Model: DELL S1909WN 18.5"
Post by el48tel »
hope you guys are going to report the error to the error report site
https://www.surveymonkey.com/s/PSPX4BetaCYW
Terry
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Terry, I could be wrong but I don't think they want that link going out to everyone. Normal error reports should still go through Corel tech support.
danielcg401
sound_card: Xi-Fi
Re: PSP X4 four or more bugs
I also found another 4th bug! In Camera Noise Removal dialog, if I change correction blend setting twice then result preview will be incorrect! Many other adjustment dialog or photo functional dialog may experience similar bugs but I do not specify more adjustments or effects that have similar bug.
Radim
ram: 4GB
Monitor/Display Make & Model: 27 inch
Post by Radim »
Please report all founded bugs as mentioned above to Corel Tech. otherwise will last "forever".
