Paintshop Pro X4 resize question
Hooterville
After I resize an image with Paintshop X4 the image on the work area is so tiny, like 1" X 1"
I'm talking a 2000 X 2000 pixel image.
How do I prevent this?
Hooterville
Re: Paintshop Pro X4 resize question
How do I get the picture to automatically go to 100% or fit to window after a resize on the workspace?
The image on the workspace shrinks to a tiny thumbnail after a resize to 800X600.
In X3 with a resize like this it automatically goes to 100% in the workspace and not a tiny thumbnail.
Anyone know how I can change this?
LindaSue
- motherboard: Gigabyte
- processor: 2.71GHz AMD Athlon II X2 215 processor
- ram: 3 GB
- sound_card: Realtek AC97 Audio [onboard]
- Hard_Drive_Capacity: 1320 GB
- Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
- Corel programs: Paint Shop Pro X2, X4, X6
Hopefully someone will have a solution because this has been a feature of PSP going back all the way to PSP5. It also seems like the bigger the original image is, the smaller it shrinks to on the screen. When I tried a 2000 x 2000 pixel image, it only shrunk to about 50% or about 5x5" on my screen. But, when the image started out at 5000 x 5000 pixels, it shrunk to 17% on the screen or about 1 1/2 inches square.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
jaxman
- motherboard: Dell Inc. 0C7195
- processor: 2.80 gigahertz Intel Pentium 4
- ram: 3GB
- Video Card: NVIDIA GeForce 9500 GT
- sound_card: SB Audigy
- Hard_Drive_Capacity: 250 GB
I don't have this problem as long as I have the following:
File : Preferences : General Program Preferences : View : After Changing Size : (here I have both options checked)
LindaSue
- ram: 3 GB
I have those two options checked and always have for all versions of PSP that I've ever used and it still happens. I've tried just about every variation of checking and unchecking those options and nothing made any difference. I've just learned to put up with it.
df
- ram: 64gb
- Hard_Drive_Capacity: 1 Tb
You could make a script.
Select the Pan or Zoom tool (hand or magnifying glass)
Start recording
Resize
click the approriate view on the toolbar (fit image to window likely)
Save recording, name it
From the Script Toolbar (you may need to activate that from the View menu) Select the script, click Edit Selected Script, click the Resize command, set that to interactive. Save and Close.
Now click View, Customize, Script tab.
Select your script, select an image, bind the two.
You'll see the icon show up in the Bound Scripts section, drag and drop the icon to where ever you want it in the workspace.
Close
Start recording
Resize
Close
Regards, Dan
Hooterville
And I thought it was only me.LindaSue wrote:Hopefully someone will have a solution because this has been a feature of PSP going back all the way to PSP5. It also seems like the bigger the original image is, the smaller it shrinks to on the screen. When I tried a 2000 x 2000 pixel image, it only shrunk to about 50% or about 5x5" on my screen. But, when the image started out at 5000 x 5000 pixels, it shrunk to 17% on the screen or about 1 1/2 inches square.
Kathy_9
- Hard_Drive_Capacity: 2TB
It happens all the time for me and I have both options checked as well. To be honest, it doesn't really bother me. I just use the scroll wheel on the mouse to bring it back to a respectable size.
Hooterville
I also have both options checked. I just thought it would be something easy to fix.Kathy_9 wrote:It happens all the time for me and I have both options checked as well. To be honest, it doesn't really bother me. I just use the scroll wheel on the mouse to bring it back to a respectable size.
The version I have is 14.0.0.332, is this the latest version?
LindaSue
- ram: 3 GB
I've got buttons on my toolbar for all of the various image viewing options so I usually click either Normal Viewing or Fit Image to Screen when that happens.
Kathy_9
Hooterville wrote:I also have both options checked. I just thought it would be something easy to fix.Kathy_9 wrote:It happens all the time for me and I have both options checked as well. To be honest, it doesn't really bother me. I just use the scroll wheel on the mouse to bring it back to a respectable size.
Yes, you have the latest version.
Pixel_Pusher
- processor: Intel Core i7-7820HQ CPU 2.90GHz 2.90GHz
- ram: 32GB
- Video Card: NVIDIA Quadro 3000M
Your mistake is to check both options. You just have to check the second option and not check the first option. Then the program reacts as you want it.
Kathy_9
How right you are.Pixel_Pusher wrote:Your mistake is to check both options. You just have to check the second option and not check the first option. Then the program reacts as you want it.
jaxman
- ram: 3GB
Works for me with both options checked. Go figure.
Tadjio
- processor: Core i7 2.8GHz 860
- Video Card: ATI HD5570
- sound_card: Sound
- Hard_Drive_Capacity: 2.5TB
Thanks for the tip - I've pushed my pixels out wide after I crop or resizeKathy_9 wrote:How right you are.Pixel_Pusher wrote:Your mistake is to check both options. You just have to check the second option and not check the first option. Then the program reacts as you want it.
Tadjio
PSP X7.2 Ultimate user
AfterShot Pro 2.1 ASPirant
Windows 8.1 64-bit Pro
Canon EOS 100D, Olympus E-PM1 & iPhone 6
