Trial Ulead VideoStudio 10
Fielding
System_Drive: M
motherboard: Asus P7P55D Evo
processor: QuadCore Intel Core i7 860 2933 MHz 22x133
ram: 3061 MB
Video Card: NVIDIA GeForce 9800 GT
sound_card: integrated in the mother board
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: LG TV/Monitor Full HD LG 42SL8000 TDT LCD
Post by Fielding »
I have adquired a set for capture VHS Video to my pc.
I installed a driver Syntek STK1160
I begin the capture video option but when 10-15 minutes recording I received unexpected error.
When a reproduce the captured clip about to the five minutos began not concordance with the audio and finally the sound is lost.
Best Regards
Re: Trial Ulead VideoStudio 10
Sea bienvenido al foro, per no há información suficiente para entender el problema ... Unfortunately, you have not really provided enough information to be able to give any sensible answer. But since you are referring to Video Studio 10 and some sort of capture device, I suspect that you have bought a fake EasyCap/EZCap device which comes with Video Studio 10 SE Please see: http://forum.corel.com/EN/viewtopic.php ... 30#p211330 Please also come back with any further information you might be able to provide about the device and exactly what the problem is. Could you also explain More about the photos you supplied. Although I have a 24 inch monitor at 1920 x 1080, I am afraid that the photos are too small for me to be able to make out any of the words...
Fielding
System_Drive: M
ram: 3061 MB
Post by Fielding »
I try with words then
The audio and video configuration is :
16:9 in the welcome window
Capture window selection in the next window
format mpeg
in options
pal system
preview with usb driver selected
frame size 720x576
80% quality
mpeg1 in advanced properties
When the capture video key is pressed the record begin.
But before 15 minutes a received a warning window : unexpected error
Reproducing the video clip recorded is in bad state : audio not syncronized.
I would like to know if I can try the last ulead trial with this usb adapter Konig
Meanwhile i have tried Windows media maker with errors. And at the present moment all seemed solved using the freeware version for personal use of Debut from NCH.
Perhaps all is well now, but I can try the last version of ulead if you think so.
Best Regards
Photos of the konig dispositive.
I can make proofs. My pc have five systems running under windows xp pro sp3
Trato de explicarme con palabras entonces.
la configuración de vídeo y audio que he puesto es :
16:9 a la entrada del programa (ventana inicial marco en 16:9)
pestaña Captura video
formato mpeg
en options
sistema pal
preview audio with usb driver marcado
frame size 720x576
80% quality
mpeg1 (en propiedades avanzadas)
Cuando le doy al botón capture empieza la captura del vídeo.
Pero cuando han transcurrido más de días minutos deja de grabar el vídeo y aparece la ventana de error : unexpected error.
Posteriormente he observado que en la reproducción del vídeo se desincroniza el sonido. Y antes de terminar la reproducción se pierde el sonido.
¿Qué datos adicionales podría suministrar ? Los pantallazos que no se ven recogen la configuración que he puesto más arriba de forma resumida.
Gracias
Post by Trevor Andrew »
When capturing using VS 10 please use Format – DVD not Mpeg.
This will provide compliant DVD Mpeg2 settings.
When using Debut from NCH is the audio capture synchronised’ or are you still having problems.?
If you are still having Sync’ problems then you may have to connect the audio (Red /White) directly to Line-In. Bypassing the Kong capture device.
I certainly agree with Trevor about the capture format. In your Spanish above, you indicated you were capturing mpeg-1. This is an old format which has mostly been superseded. What you want is mpeg-2, and as Trevor says, selecting 'DVD' as the capture format will give you that.
Although I now see that the capture device is called a Konig, the driver you mentioned above is also used by the counterfeit EasyCap device I mentioned above. That device also comes with that SE version of Video Studio (10) that you mentioned. So have a look at the link I provided above as a lot of people have had trouble with such a device and with the software which came with it. It may be time to consider buying a better device.
I am afraid I don't know if Video Studio X4 will work with the device.
Fielding
System_Drive: M
ram: 3061 MB
Post by Fielding »
trevor andrew wrote:Hi
At the present moment Debut is doing well. No problem at all.
I am a simple user, not a professional. Perhaps we can continue this post is necessary for other user in the same problem.
I have downloaded the trial of X4. I''ll wait for your future instructions. I am plenty of space in my pc.
Best Regards
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
If you Capture using Debut.
Can you Edit using Video Studio.
If it works well, no out of sync audio -
Problem solved :)
