Hi Everyone,
I am having a printing problem that started with X3 and is still present in X4. I hope that some of you might try these simple steps and see if the problem is present for you too.
Here are the steps:
Create a a New Image with these parameters:
Width: 11 inches
Height: 8.5 inches
Resolution: 72 pixels/inch
Vector Background
Grey - 16 bits/channel
Once the blank image has been created, add a line of text at the top of the image with the Text Tool. Then add a separate line of text at the bottom of the image so that you have two text object. Then send the image to your printer in landscape mode.
When I do this, only the text at the top of the page prints. The text at the bottom of the page does not. Can anyone else reproduce this?
Thank You,
Tracy
Help reproducing printing problem...
RabbitWolf
- motherboard: ASUS P8P67 DELUXE B3
- processor: Intel Core i7 2600
- Video Card: NVIDIA GeForce GTX 460
- sound_card: X-Fi Bravura 7.1
- Hard_Drive_Capacity: 256GB
- Monitor/Display Make & Model: Dell U2410
- Attachments
- sample.zip
- Sample file showing problem
- (5.49 KiB) Downloaded 115 times
Kathy_9
- Hard_Drive_Capacity: 2TB
Re: Help reproducing printing problem...
No, it's not just you. I followed your steps and got the same result - only the text on the top of the page prints.
Kathy_9
I did some additional testing and found a solution/workaround. If you "merge visible" prior to printing, both the top and bottom text prints.
RabbitWolf
Hi Kathy_9,
Thanks for testing this out...
I finally had to purchase a support incident and it took the technician about all of ten minutes to reproduce the problem. The email support was worse than useless. I already knew about using merge, but the result is very blurry and not satisfactory. Anyway, Corel is aware of the problem and will hopefully come out with a proper fix sooner rather than later.
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Or convert to raster. I always do a final merge before printing so I tend to miss...highly specific things like this.
