PaintShop Pro X4 - Keyboard shortcut broken
Robin
- System_Drive: G
- motherboard: Gigabyte
- processor: E5200
- ram: 2GB
- Video Card: Nvidia
- sound_card: Realtek
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: HP 101
Recently upgraded to this version. CTRL-O shortcut doesn't work, nothing happens.
Files can be opened okay with File/Open, but the shortcut is broken. Other shortcut
keys operate correctly.
Just me - or a bug? Using v14.0.0.332.
PS: Give us back to option to dump the Graphite theme - it's useless.
R
R
Michael Geary
- motherboard: ThinkPad W510
- Hard_Drive_Capacity: Plenty
- Monitor/Display Make & Model: 1920x1080 but not IPS :-(
Re: PaintShop Pro X4 - Keyboard shortcut broken
It's not just you. I was stopping by here to report the same bug.
vPod
- motherboard: ECS G33T-M2
- processor: Intel Core 2 Quad Q6600
- Video Card: GeForce GT 240
- sound_card: Creative SB X-Fi
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: Acer AL2017
No, it's not just you. Ctr+O doesn't work here either.
BTW, I happen to like the Graphite interface.
vPod
vPod
Robin -- please do not double post. New users have to have their first few posts approved before they actually appear. But we are volunteers who staff this Board, so we cannot be around all the time. I will delete your other identical post to avoid confusion.
As for the graphite workspace, apart from vPod above, nearly everyone else doesn't like it either. And Corel say they will bring out a new option in a patch.
Michael Geary
Actually, it's a little different on my machine. When I press Ctrl+O it opens the Save As... dialog!
As a test I tried uninstalling X4 and then deleting all registry values, AppData/Local|Roaming directories, and My Documents directories for both X3 and X4. (X3 was the first version of PSP installed on this machine.) Then I reinstalled X4. That didn't make any difference. So it doesn't appear to be an upgrade-related issue, just a bug in the new version.
LindaSue
- processor: 2.71GHz AMD Athlon II X2 215 processor
- ram: 3 GB
- sound_card: Realtek AC97 Audio [onboard]
- Hard_Drive_Capacity: 1320 GB
- Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
- Corel programs: Paint Shop Pro X2, X4, X6
Maybe they just changed what that keyboard shortcut does or elimated it completely. Do they still show it in the File menu for "Open"? They changed what Ctrl+V does at some point in time. In almost every other program that I'm aware of, and for most versions of PSP, Ctrl+V was just plain Paste. Sometime around PSPX2, they changed it to Paste as New Layer and I still have a hard time remembering that. They've also changed the shortcut keys for various tools and options over the years. For example, the shortcuts for viewing and hiding some of the toolbars and palettes changed a few versions back.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
df
- ram: 64gb
- Hard_Drive_Capacity: 1 Tb
ctrl O doesn't do anything for me. In fact I tried assigning that to something else (Twain Acquire since it didn't have anything assigned) and it still didn't do anything. In fact I tried assigning ctrl shift O to open and it still won't do anything.... unless I already have another image open. If there's already anther image open ctrl O works as it used to in previous versions (after I reset it to Open). Sounds like a little bug to me.
Regards, Dan
teknisyan
- processor: Intel Corel i5
- ram: 4 GB
- Hard_Drive_Capacity: 500 GB
Because of the new UI of PSP X4, I would assume that some of the shortcut keys will change. If you want to view all shortcut keys, you can click on the HELP MENU then select KEYBOARD MAP... If the keyboard short is now working as indicated in the Keyboard Map, you can reset your workspace. You can do that by pressing and holding down the SHIFT key then double-click on the PSP icon then when you received the message "DO YOU WAN TO RESTORE PAINTSHOP Pro TO ITS DEFAULT STATE?" just click OK.
Like reading blogs?
About Tech
About Sports
Pnoy.Me - A URL Shortener
About Tech
About Sports
jaxman
- motherboard: Dell Inc. 0C7195
- processor: 2.80 gigahertz Intel Pentium 4
- ram: 3GB
- Video Card: NVIDIA GeForce 9500 GT
- sound_card: SB Audigy
- Hard_Drive_Capacity: 250 GB
If I am in MANAGE mode, CTRL O brings up the open screen and if I select a picture it takes me to the EDIT mode. If I am in ADJUST or EDIT mode, CTRL O opens up a SAVE AS screen.
nhlisa
- motherboard: Dell XPS 8300 - 0Y2MRG A01
- processor: 3.40 gigahertz Intel Core i7-2600
- ram: 12GB
- Video Card: AMD Radeon HD 6700 Series
- sound_card: AMD High Definition Audio Device
- Monitor/Display Make & Model: Dell U2410 - 24" - 1920x1200
Adding my 2 cents here...I just tried Ctrl+0 in edit mode and mine also goes to Save As. I checked to see if the shortucts were screwed up and they aren't.
Lisa
Lisa
