PaintShop Pro X4--Wishlist for Future Versions
Babble
motherboard: ASUS M4A78T-E
processor: AMD Phenom II X4 945 3GHz
ram: 8 GB
Video Card: XFX Radeon HD6750
sound_card: Via HD sound
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Asus PA238Q
Re: PaintShop Pro X4--Wishlist for Future Versions
Post by Babble »
Here are two suggestions that are needed. The first is simple, when a selection is active change the color of the active layer. I often have a selection but it is set to hide then I forget and have trouble with a tool not working and I waste time trying to figure it out. If the layer I'm on would change from blue to red it would remind me to set the selection to None.
The second item has annoyed me for years. Many functions re-calculate every time we make a change to the setting (e.g. effects, ) and we must wait then wait again. For effects with multiple settings, put in a check box for manual update and an apply button on things that take more than a second or two to calculate. This way we can make large changes to several settings and then apply as we like.
Finally, I have run into problem with X3 using Topaz plugins in scripts. X4 is better but would crash on Adjust 5. I haven't tried it in SP2 yet, but Corel should always make sure Topaz plugins function properly even in a script.
BIG BUG
Post by BIG BUG »
Coming directly from PSP 9 I'm unhappy how this curves editor (Brightness and Contrast) works now. Moving a control point does not affect only the adjacent curves but those between other points too. This makes it very hard to get the curves right (with the interpolation in PSP 9 setting curves was a matter of seconds, now its fiddling around for minutes).
There should be an option to choose how curves are interpolated (PSP 9 style, linear, bezier, etc.).
nyukuri
ram: 4GB
Hard_Drive_Capacity: 500GB
Post by nyukuri »
right, I can only agree with what was said about the curves!!!! hope that will be changed
el48tel
motherboard: Dell Inc. 0GDG8Y A00
processor: 3.00 gigahertz Intel Core i5-2320
ram: 8Gb
Video Card: NVIDIA GeForce GT 530
Hard_Drive_Capacity: 2Tb
Monitor/Display Make & Model: DELL S1909WN 18.5"
Post by el48tel »
Curves has been there for ages - certainly in X2 - just be gentle - use the left; right; up; down arrow keys for real close work
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
I noticed on photoshop that if you rested your cursor over a part of the image, a corresponding point on the curves line appeared showing what point you needed to move, to affect that tone. This does not seem to be present in PSP and I think would be an advantage.
hcd77
motherboard: MEDION E6212
processor: 2.30 gigahertz Intel Pentium Dual-Core
ram: 3034 Meg
Video Card: Mobile Intel 4 Series Express Chipset Family
Hard_Drive_Capacity: 318.89 Gig
Monitor/Display Make & Model: Generic PnP Monitor (15.9"vis)
Post by hcd77 »
I would like Selective Colouring layers (as found in PS).
Full Open Type support.
df
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Post by df »
Don't know if this has already been suggested but I'd like to see Image Information as a palette. Also being able to select what to display on the Image Info palette would be ideal. I want to know focal length, lens used, and camera used on. Others may not care about that and want to know GPS data. If that palette could just stay open it would help with establishing a workflow.
I wouldn't be asking for this if Corel would just fix the problems with photoshop plug-ins. If PTLens could read the focal length, lens used, and camera, I wouldn't need to manually insert it. Seems pretty simple, lots of other editors do this just fine, but not Corel. OK, end rant, back to processing pictures.
Regards, Dan
cadudesun
Post by cadudesun »
Save image as "in-built PDF" format, in the same way either GIMP or Photoshop provide.
The PDF printer (even in best quality setting) doesn't provide a good output as "in-built PDF" do.
Actually, when I need to create a PDF to send to print shop I open the image create in PSPX4 from GIMP.
So, to users that send their works to be printed externally, the "in-built PDF" format would be handy (many print shop ask for PDF format, not PNG or JPEG).
Spodeworld
Hard_Drive_Capacity: 1TB
Post by Spodeworld »
I wish the Raw editor in PSP was more robust. I feel that it offers the bare minimum and does not compare to Adobe Camera RAW.
Also, I wish the sliders were easier to use. For example, the opacity slider is very clunky and extremely hard to fine tune.
Javier
processor: Intel Core2 Duo CPU P7450 2GHz
ram: 4 GB
Video Card: NVIDIA GeForce G210M
Hard_Drive_Capacity: 500 GB
Monitor/Display Make & Model: Toshiba TMDISPLAY 13.4"vis
Post by Javier »
I purchased Paintshop Por 4x only last week and had been using version 9 till then, so some of these features might be implemented already!
  • Text effects. Please add built in text effects.
    3d text. (it looks really cool when you add it to some images... for example a sphere)
    Rounded rectangles and squares ( I know there are workarounds and some basic functionality, but trust me, they're very time consuming)
    Ability to open all frames from an animated gif file.
    Ability to open avi, mp4 files: all the frames or user definable ratio. My gif animator programs let me do it and they're like... 10 years old!
    Curved wireframed grids. (3d I guess)
    Please add transparent bg conversion memory! (If you open a png file with, say, black bg, then convert that bg into a transparent bg, then copy the image with the transparent bg and then paste it into a new one, the transparency is gone and the black bg is still there. However, if you save the image with the transparency, you then close it, then you open it again, then you copy it and you paste it, voila! the transparecency is there!)
    More effects. Very few new ones have been added in the last versions.
    Increase the "recent files list to at least 100).
    The "buttonize" effect was really poor in 9, havn't tested it with this latest version.
    Selection tool by numeric value (i.e. xpixel 24, y pixel 95, etc.). This is like so essential!
    Customer support: galleries of images created by users. Let us upload them! You're COREL! WE are COREL!
    Customer support: galleries of tutorials created by users.
    Customer support: provide list of compatible plugn ins.
    Customer support: upgrade these cheapo (I know it's free and hacker vulnerable) forum software to something decent like Invision Power Board. You are COREL! Give us the best, and we'll return it with interest!
migueleonm
operating_system: Linux
System_Drive: N/A
processor: AMD Phenom II quad core P940 mobil version
ram: 4GB
Video Card: Integrated ATI 4200 discrete ATI 5650 both mobil
sound_card: Realtek
Hard_Drive_Capacity: 640GB
Monitor/Display Make & Model: 720p HD TruBrite
Post by migueleonm »
What I really want is a linux version of PSP. Now ubuntu has a software center for third parties can sell their software.
I am using the trial version and wanted to buy it but I really hate to boot windows just for photo editing, is not that I hate windows is just I prefer ubuntu and want to use only one system, not two.
Also a mac version will be welcomed because they have 10% of market share and a big portion of them use it for multimedia porpoises.
Mac: A proved successful market.
Linux (specifically, fedora and ubuntu) : A market niche that nobody wants to explore but could be a success (valve is exploring it).
Windows: OFC the desktop with biggest market share, is the platform of choice for business
SJS
motherboard: Dell Inc 0KWVT8 A03
processor: 11th Gen Intel Core TM i7-11700
ram: 16 GB
Video Card: NVIDIA GeForce GTX 1660 Ti 6GB GDDR6
sound_card: Onboard Realtek Codec
Hard_Drive_Capacity: 4 TB
Monitor/Display Make & Model: DELL U2412M
Corel programs: PaintshopPro 2022 Ultimate
Post by SJS »
The ability to disable zoom on a mouse wheel / trackball scroll. I just got a new trackball with a very sensitive scroll ring. Now when I am trying to crop or straighten or select, if I just touch a lazy fingertip to that scroll ring, I am zooming in or out! Very annoying.
I use a trackball due to hand problems, so re-training my hand may not be an option.
I can't find anything useful in my Kensington Trackball software or my Windows 7 Home premium control panel mouse settings!
spitfrog
motherboard: NZXT N7-490
processor: Intel I5-10600K 6C 12T 4_8GHz
ram: 32 Go DDR4
Video Card: Radeon RX 6750 XT 12GB
sound_card: AE-5 Plus
Hard_Drive_Capacity: 6To
Monitor/Display Make & Model: AOC Q3277 + Wacom Intuos 3 A4
Corel programs: PaintShop
Post by spitfrog »
Just a f...... button in "Adjust" and "Edit" tabs to see original files before change.
spitfrog
ram: 32 Go DDR4
Post by spitfrog »
I do a fake example, which explains why it is important to also have this button in the "edit" tab too, and not only in the "adjust" tab (like other software)
hartpaul
ram: 8 Gb
Post by hartpaul »
You can have that effect by using the layers palette and duplicating your image, then work on the top image cloning, lighten, levels etc . To see your original image in the exact same place just click the visibility toggle of the top layer on and off. Worked image on top and original below. No need for an extra button on an already busy tools options space.
Duplicating your image in the layers should be a first thing when working on images.
