I've installed all the software and I can use the Boris FX as i can find it in the effects list and drag it on to a clip. However i Can't see Mercalli in the list or find anyway of accessing it from Video Studio - any pointers welcome please!
NB I've checked the ProDAD folder that installed and it's only 15mb in size and the .corel folder is empty - I'm guessing that this may be an installation problem but again any pointers welcome
How to access Mercalli plugin in X4 Pro Ultiate
Re: How to access Mercalli plugin in X4 Pro Ultiate
Part of the problem is being in a position to answer such questions. This is a user to user web board, not a Corel board as such. There are only one or two people associated with Corel who occasionally visit here. And those of us who are regulars knew nothing about the release of VS X4 Ultimate before it was released. In other words, we know nothing about how Mercalli in particular works. So you yourself are one of the first people who have actually got it who has come here with questions...
So far, there has been only one other user who has asked questions, although someone else has answered it. It is not the same as your question, but all I can do is refer your to it in case it is of any assistance: please see http://forum.corel.com/EN/viewtopic.php ... 24#p227324
stuart_f
- motherboard: ASUSTEK Berkeley
- processor: INTEL CORE 2 QUAD CPU Q6600 2.40 GHZ
- ram: 3GB
- Video Card: NVIDIA GEOFORCE 8400 GS
- sound_card: REALTEX INTEGRATED HIGH DEFINITION AUDIO
- Hard_Drive_Capacity: 500GB
Thanks Ken - I hadn't realised this waa quite so hot off the press
I've now put in a request to Corel Support and will report back as appropriate
pepegota
- motherboard: ASUS TUF Z390-Plus
- processor: Intel i9 - 9900k
- ram: 64 GB
- Video Card: GTX 1660 6GB
- sound_card: On board sound
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: Ben Q, "21" LCD
- Corel programs: VS 2018, VS 2019, VS 2020
How to proceed:
1. Locate the FX.
2. Activate your clip in the timeline by double-clicking it.
3. In FX, click proDAD.
4. Drag the Mercally 2.0 entry to the selected video clip (via drag & drop) in the Corel Video Studio timeline.
5. Now click on the Customize Filter button.
6. The Mercalli 2.0 Settings dialog starts. Here you can define the settings of your choice.
7. Click OK in order to go back to Corel Video Studio.
8. If you want to start Mercalli 2.0 again, activate the clip again (double-click), go to FX / proDAD / Mercalli 2.0 and click the Customize Filter button.
Hope this helps.
1. Locate the FX.
Hope this helps.
stuart_f
- ram: 3GB
Thanks for the suggestion - I thought this might be the case but unfotunately although BorisFX appears in the effects list prodad doesn't
Looks likes a !"£$%%^ reinstall when I've alrady downloaded and installed all the freebie templates - thanks a bunch Corel
Unless anyone else has a good idea
stuart_f
- ram: 3GB
Obviously not Corel who have told me to reinstall - I suspect this is going to be a massive waste of time but here I go
stuart_f
- ram: 3GB
As expected - uninstalled reinstalled with virus protection and firewall off and still no Mercalli in the FX
geoffschultz
- motherboard: Gateway TBGM01
- processor: 2.67 gigahertz Intel Core i7 920
- ram: 9 GB
- Video Card: nvidia GeForce GTX 650
- Hard_Drive_Capacity: 4 TB
The "problem" is that you have an earlier version of VS installed and the plugin gets installed in the earlier version. I had X3 installed and noted that the plugin appeared in there, but not in X4. I uninstalled both versions and re-installed X4 and Mercalli now appears.
-- Geoff
-- Geoff
stuart_f
- ram: 3GB
Thanks for the advice Geoff.
It looks like the installer has put it in every version of VideoStudio I've got apart from the right one (!)
However, fortunately, it looks like uninstaling of earlier versions is not necessary as copying the file:
proDADMercalli20Corel4.vft from one of the earlier folders:
e.g.:
C:\Program Files (x86)\Corel\Corel VideoStudio 12\vft_plug
to the correct folder:
C:\Program Files (x86)\Corel\Corel VideoStudio Pro X4\vft_plug
seems to work
PHEW!
e.g.:
seems to work
PHEW!
