Chapter points, I must understand them wrong
gms9810
processor: Intel Celeron M processor 430
ram: 4GiG
Hard_Drive_Capacity: 120 GB
Post by gms9810 »
The concept of chapter points seemed simple to me but I must not have it right. I thought I could set chapter points in the timeline and name them what I wanted then they would appear as chapters on the dvd burning menus. They don't appear anywhere. I started with dvd factory 10 then went to 7SE, I can set them in dvd factory and they work fine. Is there a bug in the software, am I not doing it right or am I completely misunderstanding the concept? I've searched the threads but don't know much more than I started.
Additional stuff I have and use most:
Gimp, Inkscape, Xara extreme 5, Swish max, Swish studio, Swish Swish video, Audacity, TurboCAD 15, Mypaint, Xnview, and I have a bamboo pen & touch.
I use a LOT of other stuff too.
LarryF
motherboard: Asus M4A88TD-V EVO USB
processor: Phenom II X4 965
ram: 4 Gb
Video Card: Radeon HD5450
sound_card: Realtec HD autio
Hard_Drive_Capacity: 750 Gb
Monitor/Display Make & Model: Acer P191w
Re: Chapter points, I must understand them wrong
Post by LarryF »
Hi there,
If I understand your question correctly, you are using VideoStudio Pro X3, then DVD MovieFactory 7SE to author the DVD. Unfortunately, chapter points created in VS X3 do not get transfered over to, MovieFactory 7SE. If you want chapters in your final DVD you have to create them in MovieFactory. I hope that answers your question.
Larry
Post by Trevor Andrew »
You are correct in thinking there is a problem in using chapter points from the edit timelines.
There is a post where myself and Ron performed extensive tests. Confused me!
http://forum.corel.com/EN/viewtopic.php ... it=chapter
Chapter points within X3 timeline will be preserved within the rendered mpeg2 file.
Then inserted to DVD MF7SE will be recognised by using Insert Scenes as Chapters.
However I must stress that you are best to create the chapter points within the Burner Module and not in the Edit Timelines.
gms9810
ram: 4GiG
Post by gms9810 »
I tried it in both 7SE and 10. it seems that I can only use them if i make them in the burning process.
