PSP X. White (255,255,255) is not "white"
I don't use PSP enough to know what I might have clicked on or changed, but WHITE is not white, but a cream color. When I mouse over the color it is 255,255,255 with no texture. If I copy a section of "white" in PSP and past into another program, it is true white...so it's something PSP is doing.
wds937
- motherboard: Dell 0HN7XN A01
- processor: Intel Pentium Dual Core E5800 - 64-bit - 3.20 GHz
- ram: 4 GB
- Video Card: Intel G41 Express - integrated
- sound_card: Realtek High Definition Audio - integrated
- Hard_Drive_Capacity: 320 GB
- Monitor/Display Make & Model: ASUS VS247
Re: PSP X. White (255,255,255) is not "white"
Did you change any of the color profile settings (File > Color Management...)?
Another possibility is that the Windows 7 color scheme you are using is not completely compatible with PSP X. There are some interactions between certain Windows 7 color schemes and PSP versions 9 and X (but none that I have seen with PSP version 8 or versions XI and later).
That was it, Thanks! Turning it off returned PSP to a true white color. Usually I'd remember changing as it's something that takes a couple of clicks to turn on/off.wds937 wrote:Did you change any of the color profile settings (File > Color Management...)?
